Manual tranny fluid for 6th gen? Synthetic...
Old Apr 4, 2007 | 07:54 PM
98savage's Avatar
Default Manual tranny fluid for 6th gen? Synthetic...
I was running Royal Purple Max ATF in my automatic tranny. Going to be doing a manual swap so I need to know what kind of fluid I should get. I'm wanting to run synthetic, so should I run Max-Gear or Synchromax?
Taken from Royal Purple's website:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Max-Gear is recommended for use in truck, motor home / RV, and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Synchromax is recommended for manual transmissions that specify an automatic transmission fluid or motor oil. It is also ideal for 4x4 transfer cases and / or 2-cycle and 4-cycle motorcycle gear boxes.</TD></TR></TABLE>
I know Synchromax says it is ideal for 2 cycle and blah blah, but I'm not sure whether the tranny needs ATF or what.
Old Apr 4, 2007 | 07:59 PM
stinker504's Avatar
Default Re: Manual tranny fluid for 6th gen? Synthetic... (98savage)
I just did a 5spd swap with a fully rebuild H23 trans in my 6th gen. Gearspeed also installed a LSD and they recommend only using honda MTF. So does the majority of people on HT.
Old Apr 4, 2007 | 08:56 PM
98savage's Avatar
Default Re: Manual tranny fluid for 6th gen? Synthetic... (stinker504)
The only reason I was running synthetic in my auto was because of the heat issue I was having. If you're doing fine on Honda MTF and everyone else is as well, then I will use that. I'm just running basic bolt ons with occasional spray. Going to install a stage 3 racing clutch as well.
Old Apr 5, 2007 | 08:59 AM
Gearspeed-Performance's Avatar
Honda MTF is what we recommend Do not use any type of Gear Oil!!!
Old Apr 5, 2007 | 10:14 AM
98savage's Avatar
Default Re: Manual tranny fluid for 6th gen? Synthetic... (GearSpeedEF7)
Gotcha....Honda MTF it is
Old Apr 5, 2007 | 11:10 AM
JimBlake's Avatar
Yeah, MaxGear is for trannys that have been designed to take API GL4 or GL5 oil. That's NOT a modern Honda manual tranny. They're designed for Honda MTF which is close to a 10w-30 engine oil.
Old Apr 5, 2007 | 11:30 AM
98savage's Avatar
Default Re: Manual tranny fluid for 6th gen? Synthetic... (JimBlake)
There won't be any problem running a stage 3 clutch and occasional NOS on Honda MTF right?
Old Apr 6, 2007 | 10:03 AM
standbackimapro's Avatar
You dont NEED to use honda Mtf.. I use BG synchroshift II, supposed to be the best transmission fluid for fwd manual cars, And honestly, i had a laser and the trans shifted sluggish,i put in the synchroshift and it shifted soo smooth
Also ive used GM synchro mesh, and Lucas transmission fix mixed with 75w140
airikkCRX
Jul 2, 2010 11:49 PM
Kaliona
38
Aug 3, 2009 05:53 PM
boostmee
Apr 10, 2007 01:11 PM
LshatchTurbo
Dec 15, 2001 03:34 PM
DamonBoost
Oct 27, 2001 02:28 AM
