Flakes in the oil pan, rattle noise at certain RPM
Old Apr 4, 2007 | 06:44 PM
99CivicSiBrian's Avatar
B A N N E D
Default Flakes in the oil pan, rattle noise at certain RPM
As the topic states. I've noticed more rattle than before and I had to take the pan down anyway. Seal was leaky and the drain plug had been replaced with a universal unit.
Anyway after a day of letting the oil drain away, I discovered gold!! It's in the bottom of my pan. So I'm not thrilled, I put this D15B in to rectify this problem last May.
Anyone with experience can chip in. . .
but should I just swap blocks/motors, or should I replace the bearings while the motor is still in teh car? I ahve access to lifts and machine shop stuff but I've never done any bearing work so I'm hesitant do to it . . . some one give me some confidence!!!
Word.
B
Old Apr 4, 2007 | 06:48 PM
Heart4Audio's Avatar
what's more time/cost effective for you? try the bearings. and where is your rattle coming from? and what rpm levels/
Old Apr 4, 2007 | 07:47 PM
EG2Driver's Avatar
Default Re: (JJSpecTuning)
you gotta check the clearance and use proper care when doing work on such delicate engine parts. You are better off swapping the whole thing, lot less trouble down the road.
Old Apr 5, 2007 | 04:01 AM
B A N N E D
Default Re: (DeadEnd9009)
So then the next question -
HMotorsOnline for a D15B, or limp around the bad motor while I learn to rebuild my old D16z6. . . hmmmm.
THx for input yall.
B
Old Apr 5, 2007 | 04:11 AM
pythoner's Avatar
if you are already seeing glitter....it will be gone very soon
Old Apr 5, 2007 | 04:47 AM
hatchness135's Avatar
Default Re: (pythoner)
a swap sounds the most efficient way imo...cuz if you go and fix the bearings and its something else, then it just becomes a pain the ***
Old Apr 5, 2007 | 05:57 AM
Sahwn's Avatar
if you keep running it your crank will be out of round and no good. You will need a new crank.
Just buy a used bottome end from someone on here or junk yard. hell buy a used motor I think Bense has a long block
Old Apr 5, 2007 | 06:00 AM
Sahwn's Avatar
yep he has one. He is a good guy and a mod:
http://www.hondamarketplace.co...21524
Old Apr 6, 2007 | 05:54 PM
B A N N E D
Default Re: (redsnapper)
Thats quite a distance from me, but I am considering it. Same as the motor that I have in there now. . .
I thought the rattle was something tragic, but I'm now thinking it's my knock-off JDM-Mugen-Ebay oil filler cap. . . the threads are tight but the cap has play . . . and upon tapping the cap it rattles. I'll switch to OEM Honda and see what happens.
Until I hear further noise, I'm going to keep working toward building a spare block but I'm not going to baby the motor that is in the car. It's got an H on the valve cover somewhere.
B
Old Apr 6, 2007 | 06:40 PM
Jay_Sensing's Avatar
If there is brass glitter in your pan man, there is no sense in fooling yourself into what it "could" be. It's a bearing. It knocks momentarily on startup and then at a certain RPM only say, 3000-3400.
Just stop now before you wreck the head (valve guides) and other things, pull it and replace it or rebuild the bottom.
<---- learned the hard way several times about knocks and milking them.
Old Apr 6, 2007 | 10:30 PM
dftravis's Avatar
Default Re: Flakes in the oil pan, rattle noise at certain RPM (99CivicSiBrian)
Forget about it. Just get something bigger and better. You will come out stronger in the end and it will all be worth it.
Old Apr 6, 2007 | 10:54 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: Flakes in the oil pan, rattle noise at certain RPM (dftravis)
i rebuilt my d16z6 in 2 days..................just rebuild the d16z6 real quick swpa longblocks easy rebuild the d15b and sell it, not many on ht could build motors
Old Apr 7, 2007 | 10:31 AM
B A N N E D
Default Re: Flakes in the oil pan, rattle noise at certain RPM (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">i rebuilt my d16z6 in 2 days..................just rebuild the d16z6 real quick swpa longblocks easy rebuild the d15b and sell it, not many on ht could build motors </TD></TR></TABLE>
Yeah.
I've got the stock D16Z6 out and part way apart. I've never done bearing work so I've got to admit I'm intimidated and hesitant. I need to determine if hte crank in the disassembled D16Z6 is still good or what. Is there a link or anything online somewhere where I can learn how to do this whole thing?
Old Apr 7, 2007 | 11:34 AM
YoungKadafi's Avatar
i never find any shavings, but i have a rattle at rpms 2000-2200 rpms. Its internal.
Its been this way for about 1 year. So i dont know, post up pics the shavings.
Old Apr 9, 2007 | 04:17 AM
B A N N E D
Default Re: (YoungKadafi)
har. I think I washed them down the parts cleaner drain lol.
Any thing wrong with using Mobil 1 synthetic? I used it in the last motor and it started to have bearing problems, and I've used it in this motor since I put it in, but who knows what happened b4 I had it.
B
Old Apr 9, 2007 | 08:40 AM
^^^^hmmmm....i think i started having the noise issue shortly after I started using mobil1. Im using royal purple now, I like it.
Old Apr 9, 2007 | 08:07 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CivicSiBrian &raquo;</TD></TR><TR><TD CLASS="quote">As the topic states. I've noticed more rattle than before and I had to take the pan down anyway. Seal was leaky and the drain plug had been replaced with a universal unit.
Word.
B</TD></TR></TABLE>
You are a car thief.
http://www.honda-acura.net/for....html
Old Apr 9, 2007 | 08:15 PM
gezzuzz's Avatar
theifs sould be banned from h-t
NEAL FRISBIE
Mar 1, 2011 09:42 AM
streetracerjoey210
Feb 8, 2009 09:31 AM
obuhmyuh
26
Jun 27, 2008 11:23 AM
andrewasf77
25
May 19, 2004 09:51 AM
Kimbo
Apr 25, 2003 09:42 AM
