91 civic si with stock motor, can i use an ecu from a DOHC integra to riase my redline
Old May 26, 2002 | 04:11 PM
tinyrally's Avatar
Default 91 civic si with stock motor, can i use an ecu from a DOHC integra to riase my redline
Hello Everyone,
I have a 91 civic si with stock motor, can i use an ecu from a DOHC integra to riase my redline, and my fuel mix, and timing? Will this do anything for me? Is this possable?
Can someone please give me any info?
Thanks guys
Chris Thompson
Waterboys Racing
Old May 26, 2002 | 04:14 PM
Urban Business
Guest
Posts: n/a
Default Re: 91 civic si with stock motor, can i use an ecu from a DOHC integra to riase my redline (tinyrall
90-93 (mabey 91 i dont remember) obd0 teg ecu will work. you will run rich w/o mods raising redline on stock valvetrains isnt a good idea. valves will stretch and you can spin berrings.
Old May 26, 2002 | 04:20 PM
tinyrally's Avatar
thanks i didn't know about the valves could i put bigger valves in to correct that problem? would there be other problems involved
Thanks
Chris Thompson
Waterboys Racing
Old May 26, 2002 | 05:03 PM
Steve91's Avatar
Valve's will stretch? That's a new one
Old May 26, 2002 | 06:01 PM
Frosty_spl's Avatar
What will happen during high rpm is the valves float, causing retainers and or springs to break, or the valves to stick open. then they fall down into the combustion chamber.
I dont think a different ecu will do anything for performance.
[Modified by Frosty_siR, 7:03 PM 5/26/2002]
Old May 26, 2002 | 08:01 PM
Reverend's Avatar
I think he's right - I think you're better off just getting your ECU chipped somwhere for a higher redline and better fuel curve, if that's all you want.
NINE-ONE-CIVIC
21
Sep 16, 2012 12:13 PM
SwapShopR
Oct 19, 2005 11:37 AM
civickidd99
May 2, 2002 03:55 PM
W0oT
Aug 3, 2001 10:34 PM
