intermittent starting problems
Old Apr 4, 2007 | 03:46 PM
speedswing's Avatar
Default intermittent starting problems
Thanks for the help so far but this thing has me stumped. Went to tow my car last night and it started right up. This is after picking my wife up from work and it just cranking and no start.
see these post from this past week.
https://honda-tech.com/zerothread?id=1939425
https://honda-tech.com/zerothread?id=1942401
I think I'll change the ignitor. Since it has not been changed yet.
anymore ideas?
Old Apr 5, 2007 | 02:27 PM
speedswing's Avatar
Default Re: intermittent starting problems (speedswing)
bump 4 some help
Old Apr 5, 2007 | 03:16 PM
BADHDRIVER's Avatar
(main relay) location driver side,beside fuse box, behind dash panel...(close to your left foot area.. Now to test the MR you need for the no start again, quick way kick or bang on it to see car will start... if no try,checking spark and fuel pressure. if both to not work at the same time no strart it's the main relay.
dealer cost $50.00can... it happen to me on two honda last owned 91 & 93 civic...
also, if you have no start with fuel pressure its your complete Ignition Distributor need replacing rebuilt $250
or really can be only a bad ground cable from battery, bad positive cable to starter, bad starter coil, bang hard on coil with no start...check passenger ecu under the carpet for LED code flash... I hope this help you alot...
Modified by BADHDRIVER at 4:32 PM 4/5/2007
Old Apr 12, 2007 | 12:33 PM
m3tech95's Avatar
I had this type of problem w a 98 lx... would crank and crank did all of the above...was getting spark, fuel, fuses good and relays, ground was good turns out it was as simple as the distributor was on the crank upside down... ( meaning i had to crank the pin to do a 180 degree turn ) as soon as i did that started right up.... thought this might help especially if you did any thing to the dizzy cap or rotor
Old Apr 12, 2007 | 12:35 PM
m3tech95's Avatar
if you ve ever taken off the entire distributor check to make sure its lined up properly..
Old Apr 12, 2007 | 12:36 PM
m3tech95's Avatar
also try using starter fluid if it starts then its your fuel pump going ( would explain itermittent starts)
fortymcpants
11
Jul 19, 2008 08:03 AM
jury
Jan 1, 2007 10:57 AM
SpoolinEK9
Mar 15, 2005 04:25 PM
ludicrous
Jun 17, 2004 08:20 PM
