Need some suggestions on a build
Old Apr 4, 2007 | 03:23 PM
grjp1988's Avatar
Default Need some suggestions on a build
As youk now im currently rebuilding my R, right now i have a 4340 eagle knife edged ls crank 11:0:1 nitrous pistons eagle rods bored .020 over and have a cylinder gurdel pressed in the block... im lookin for some things for my head... i have spent around 2500-3000$ on the labor and parts.. for the head im getting a 3 angle valve job port polish, give me some insite on the injectors cams, and gears.. fuel rail any of the things i would need let me know and if anyone has and good parts around let me know thanks Greg
Old Apr 4, 2007 | 03:59 PM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: Need some suggestions on a build (grjp1988)
pm'ed
Old Apr 5, 2007 | 11:09 AM
grjp1988's Avatar
Do you think i should go with the skunk2 pro series 2 or stage 3, the problem is my motor is not a 1.8 anymore will this change anything?
Old Apr 5, 2007 | 11:38 AM
itrSteez's Avatar
you definitely don't have the compression to run any of skunk's pro line.... run jun 3's or m22x's
Old Apr 11, 2007 | 10:04 PM
grjp1988's Avatar
Well after its all said an done the guy i know that is doing my motor said it should be around 11.8.1 im lookin to go s2s2 but im thinkin of running the pro 2's cause i saw a guy with a simmiler setup running a little higher than oem compression on a ls vtec build and he gained 17+ hp from stock to pro 2's
Old Apr 11, 2007 | 10:48 PM
neo_'s Avatar
Default Re: (grjp1988)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">Well after its all said an done the guy i know that is doing my motor said it should be around 11.8.1</TD></TR></TABLE>
How are you going to gain 0.8:1 CR? Milling the head, decking the block, head gasket, flat faced valves?
Old Apr 11, 2007 | 11:00 PM
grjp1988's Avatar
my dad sometimes lies to me about little things maybe they are 11.5.1 pistons which im pretty positive they are.... so :edit:
Old Apr 12, 2007 | 04:27 AM
itrSteez's Avatar
get a spare PR3 head and send it off for an RLZ or Alaniz Port and Polish job. then when it comes back swap all your internal stuff over and sell off your old cast. You'll yield a very high flow with either one of those that will make a world of difference.
Also I heard that ImportBuilders is now sending out ported ITR manifolds for $250 if you send them your core (can anybody verify this?)... if not you can buy one for 575 then sell off your old one, also match port your TB... And why not a hondata IM gasket while we're at it.
I'm still sticking to my guns that Pro 2's might be overcamming, but I guess we'll have to see...
You might want some beefier injectors, I'd suggest some RC 370CC's
Old Apr 12, 2007 | 01:11 PM
grjp1988's Avatar
thanks steez the guy thats doing my machining builds hemi motors for a guy that runs 5's steve engle quickest car around where i live... he is a well know guy around cincinnati so ill just stick with but my buddy said he is going to stock itr im cause is edlebrock one is to big and his car is fully built 225whp but yeah the injectors i will do thanks
Old Apr 12, 2007 | 01:18 PM
holy run on sentence Batman
Old Apr 12, 2007 | 01:28 PM
itrSteez's Avatar
the IM i was referring to is the Import Builders ported ITR manifold.
salvi2dafullezt
May 13, 2012 08:51 AM
EduardoDC5
19
Jan 19, 2009 03:35 PM
parfait2882
Feb 14, 2007 08:53 AM
dj_seloe
Aug 26, 2004 07:16 AM
SoulSurfer
Jul 21, 2002 11:15 PM
