Deegreing Blox Type B's, specified peak lift/center ??
I wonder at what deegre the Blox Type B's have their specified peak lift/center position?
I have mailed Blox without any answear....
To degree the cams you don't even need the peak lift location. What you should be looking for is the lobe seperation angle and Lobe Center to install them at. Most cam cards use opening and closing #'s based on .050" lift at the valve.
