Tapered Ring Compressor
Old Apr 4, 2007 | 01:13 PM
Crazydave's Avatar
Default Tapered Ring Compressor
does anyone know if there is someone that makes a tapered ring compressor in the size of 75.25mm
I found 75.00mm and 75.50mm,
but not a 75.25mm
Thanks
Old Apr 4, 2007 | 04:13 PM
NJIN BUILDR's Avatar
Default Re: Tapered Ring Compressor (Crazydave)
Total seal has some adjustable tapered ring compressors,but I don't know if in that range.
Old Apr 4, 2007 | 04:32 PM
Crazydave's Avatar
Default Re: Tapered Ring Compressor (NJIN BUILDR)
I was hoping for those totally pimp tapered non-adjustable deals like summit and ARP have.
btw I did check out the total seal ones close but not quite, thanks
I will keep looking for a 75.25mm non-adjustable
guess I should have just gone with the 75.50mm overbore
Modified by Crazydave at 5:43 PM 4/4/2007
Old Apr 4, 2007 | 07:46 PM
I've had excellent luck with the adjustable aluminum tapered ring compressors.
Also B&B will make a custom size one for you. http://www.stefs.com/bandb/pro...s.htm
Old Apr 5, 2007 | 07:48 AM
Crazydave's Avatar
Update:
I contacted B&B
They no longer make custom tapered ring compressors.
Old Apr 5, 2007 | 05:16 PM
Can't say I didn't try
If you really want this,try posting in the fab section.It's a easy machine project if you can find someone willing to take the time.
Cynical 1
Oct 16, 2013 07:18 PM
Spawne32
Oct 20, 2012 10:05 AM
LSVtechnologytur...
Jul 12, 2005 07:01 AM
Aeka GSR
Apr 14, 2003 05:24 PM
