why doesn't my car pull in vtec
Old Apr 4, 2007 | 10:52 AM
badassmthr4000's Avatar
Default why doesn't my car pull in vtec
ok i got a 94 integra rs with a gsr motor with header intake exhuast and intake manifold i think it has a b16 throttle body and fuel rail. i have a p28 with a s300. at first i had just a p28 none chipped and i could hear vtec open but i didn't feel anydiffrece in the way it pulled. someone told me it could be the ecu so i bought s300 and put the gsr calabration on it and it pulls the same i have a b16 tranny on it so i don't know why it is like this
Old Apr 4, 2007 | 01:35 PM
94typeR's Avatar
Default Re: why doesn't my car pull in vtec (badassmthr4000)
did you check your vtec fluid?
Old Apr 4, 2007 | 03:28 PM
nate_2k5's Avatar
Default Re: why doesn't my car pull in vtec (EH2typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH2typeR &raquo;</TD></TR><TR><TD CLASS="quote">did you check your vtec fluid?</TD></TR></TABLE>
exactly, its amazing how many ppl don't check the vtec fluid
you should feel pull at a little over 4k (i know ido in my LS), vtec opens at 4400 so it won't pull that much harder
Old Apr 4, 2007 | 03:31 PM
tomlinson619's Avatar
Default Re: why doesn't my car pull in vtec (nate_2k5)
u wont feel vtec without bigger cams
Old Apr 4, 2007 | 03:33 PM
doood's Avatar
been there done that
that intake manifold isnt helping you any if the ecu hasnt been tuned
Old Apr 4, 2007 | 04:15 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: why doesn't my car pull in vtec (doood)
well if you have s300 take it to a tuner/dyno and get it tuned, you will probably not notice vtec more but it will show if its working and you will get some more hp
Old Apr 4, 2007 | 04:25 PM
401tuner's Avatar
Default Re: why doesn't my car pull in vtec (skunk2 VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2 VTEC &raquo;</TD></TR><TR><TD CLASS="quote">u wont feel vtec without bigger cams </TD></TR></TABLE>
agreed, your not going to feel much on stock motor.
Old Apr 4, 2007 | 04:28 PM
94typeR's Avatar
if you wana feel vtec, raise the crossover 500-1000rpm
youll feel it then
Old Apr 4, 2007 | 04:36 PM
Tornadom's Avatar
GS-r cams + single stage intake manifold =crap!
It can be done, and it can be tuned well, but in all reality the GS-R cams are designed to work the best in conjunction with the 2 stage intake manifold. If you were to swap the cams out in favor of any other b-vtec cam you would "feel vtec" more. With out knowing what else (if anything) is done to the motor, it is tough for me to offer any cm suggestions... although ITR/CTR cams are a popular choice for mild N/A builds.
^This man/woman knows what's up.
Old Apr 4, 2007 | 04:42 PM
im going to have to disagree with this statement
for one if the vtec isnt working you would feel a noticable difference when it does work...
and stock gsr cams carry power nicely to 7500-7800 rpms
Old Apr 4, 2007 | 04:56 PM
martyball619's Avatar
Default Re: why doesn't my car pull in vtec (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>false info.. stock gsr cams peak out at 7600 rpms.. u dont feel much with them.. and a stock gsr vtec kicks in at 4400 rpms.. u dont feel anything.. maybe just a tad bit.. but nothing to brag about.. throw some cams in there and raise the vtec xover and you'll definitely feel it
Old Apr 4, 2007 | 05:54 PM
nate_2k5's Avatar
Default Re: why doesn't my car pull in vtec (DC2SiR)
if you want to feel it, do like i am, brian crower stage 3 cams on 12:1 compression, it should hit like abdul hodge
Old Apr 4, 2007 | 08:13 PM
how do yoou check the vtec fluid
Old Apr 4, 2007 | 08:21 PM
DS002's Avatar
Banned
Default Re: (badassmthr4000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badassmthr4000 &raquo;</TD></TR><TR><TD CLASS="quote">how do yoou check the vtec fluid</TD></TR></TABLE>
Its called oil
its all about power to weight , you wont feel it so much in an integra because it weighs more and the increase in torque is minimal . But in a light weight chassis you might slightly notice an increase in pull
all in all .... vtec is garbage
Old Apr 4, 2007 | 08:23 PM
italionstallion888's Avatar
dipstick
Happiest92Ricer
11
May 31, 2013 06:49 AM
albertleee
20
Oct 31, 2007 06:18 PM
xsi_racer
Dec 4, 2006 10:48 AM
matt87
Sep 10, 2005 07:27 AM
GSR-T-
May 21, 2003 07:07 AM
