crower cams in turbo h23, lots of rattling.
Old Apr 4, 2007 | 10:41 AM
jaywoodz's Avatar
Default crower cams in turbo h23, lots of rattling.
I have adjustable crower cams in my h23, and I really want to get the valves adjusted because of how loud the rattling is on my car. Since I have a stock drivetrain, I can't really do much else. I was told that if I try to adjust the valves, I will seriously damage my valves. Does this sound like a true statement?
Old Apr 4, 2007 | 10:46 AM
Hawkze_2.3's Avatar
Default Re: crower cams in turbo h23, lots of rattling. (jaywoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaywoodz &raquo;</TD></TR><TR><TD CLASS="quote">I have adjustable crower cams in my h23, and I really want to get the valves adjusted because of how loud the rattling is on my car. Since I have a stock drivetrain, I can't really do much else. I was told that if I try to adjust the valves, I will seriously damage my valves. Does this sound like a true statement?</TD></TR></TABLE>
Sounds like a crap statement. Check the valve clearance and if it's not set to spec, then set it right.
I guess if you set the valve lash to some crazy number you could damage the valves, but why would you do that
Old Apr 4, 2007 | 11:00 AM
mgags7's Avatar
x2
whoever told you that is....well.....wrong
adjust them....there was a thread the other day on which tool to use, get the snap on one
Old Apr 4, 2007 | 11:47 AM
sskyr32's Avatar
Adjusting the valves is complicated kindof, I would let somebody who has done it before do it, not worth risking a motor.
Old Apr 4, 2007 | 11:59 AM
manbearpig's Avatar
Default Re: (sskyr32)
It's quite simple with the diy...
Old Apr 4, 2007 | 07:35 PM
kdt3's Avatar
why didnt u adjust them the same time the cams were installed?
Old Apr 5, 2007 | 04:25 AM
jaywoodz's Avatar
Default Re: (kdt3)
okay ** UPDATE **
my stock cams were sent off to crower to get adjusted, and that's why I can't adjust the valves, sounds better now lol
Old Apr 5, 2007 | 04:32 AM
PirateMcFred's Avatar
Default Re: (jaywoodz)
What?
How do you "adjust" cams? Can you elaborate on what Crower is doing?
Pirate
Old Apr 5, 2007 | 06:33 AM
jaywoodz's Avatar
Default Re: (PirateMcFred)
sent them off to get that custom done to the specifications I wanted.
Old Apr 5, 2007 | 09:53 AM
mattsnooz's Avatar
wha? valve adjustments are part of routine maintenance. do it every 30000 miles or when ever valves move out of specification. makes a world of difference with fuel economy, burning oil, internal friction etc etc etc. If its a ticking most noticible at idle just do a valve adjustment. (DIY valve adjustment) &lt;run search on it. its pretty simple. it can be done within about 45 minutes after car is jacked and front driver side tire is off.
Old Apr 5, 2007 | 03:16 PM
92bluepreludeSi's Avatar
Default Re: (mattsnooz)
what specs are you having done to the cams?
envisioning
Jan 14, 2009 03:39 AM
jprelude92
Jan 11, 2009 08:08 PM
dk4ever
Oct 12, 2007 06:43 PM
ixcryxblood
Mar 8, 2005 08:51 PM
baddboy
Mar 18, 2003 08:30 AM
