type r suspension on ef hatch ??
Old Apr 4, 2007 | 10:33 AM
jdmcivicturbo's Avatar
Default type r suspension on ef hatch ??
cant seem to find anything on this subject out there in the world... . i have ran into a great buy for the 96-97 type r suspension with the wheels.. i love those wheels.. . its almost like the rota circuit 8's on ef's. but thats alittle played out. so im thinking about doing a suspension swap to the 96-97 type r's they are still 4 lug how ever they are 4x114. with the suspension and white wheels w/ tires they want $1000.
im sure the whole knockle swap wont work here. any body know if the bearings are the same size so i can get them pressed on ?? i know the back are direct replacement.
how about the front rotors ? cause if i get them pressed would the rotor work with the caliper setup i have now. ( 91 Ls all the way around ) if not, would the type r caliper bolt up to the Ls hub, but pressed with the 4x114 spindle and type r rotor.. which caliper?? basically are the type r 96-97 rotors the same as 91 Ls, and are the bearings the same size.. hahha hope you guys get what im asking here.. any feed back would be great..
Old Apr 4, 2007 | 10:37 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: type r suspension on ef hatch ?? (jdmcivicturbo)
Ask these guys: https://honda-tech.com/zerothread?id=1932120
Old Apr 4, 2007 | 11:33 AM
Default Re: type r suspension on ef hatch ?? (wiZCo)
thanks wizco.... you're the shizz.. nitz... lol.. thanks man..
jimmysteezen757
Apr 17, 2009 09:03 AM
NAturalDC2
Suspension & Brakes
Mar 29, 2005 06:35 PM
