Finally!! RMS divided t4 top mount
Old Apr 4, 2007 | 10:32 AM
Teglove2's Avatar
Default Update!! RMS....our ramhorn t3
Finally after many months of getting my **** together i finally finished our t4 divided top mount and i couldnt be happier with it. Ill let the manifold do the talking. Also pictured are my intercooler mods, enjoy!
gt4202
Update: Welded!
Well....after a couple more weeks of busting *** we finally finished up our t3 manifold. I dont know which one i love more lol.....
Will post the finished product tomorrow...Ryan
Modified by Teglove2 at 6:57 PM 4/5/2007
Modified by Teglove2 at 7:01 PM 4/20/2007
Modified by Teglove2 at 7:02 PM 4/20/2007
Old Apr 4, 2007 | 11:31 AM
super_mut's Avatar
omfg fap
Old Apr 4, 2007 | 12:07 PM
meotch's Avatar
Default Re: (super_mut)
that is a bigggg **** of a turbo.. Im liking the intercooler ram-dealy thing too.
good job.
Old Apr 4, 2007 | 12:26 PM
shrums-EG6's Avatar
Default Re: (meotch)
god fn damn thats one big turbo
Old Apr 4, 2007 | 12:32 PM
k24em2's Avatar
Default Re: (shrums)
You should make the inlet on the ducting for the intercooler smaller than the core size. Glad to see someone finally using a proper duct instead of just cutting holes in the bumper.
Old Apr 4, 2007 | 01:48 PM
Dunc's Avatar
BCICAN
Default Re: (k24em2)
Looking good man. Your arms look like you're lifting weights or something trying to put that buffalo sized turbo in there!
Old Apr 4, 2007 | 01:53 PM
turbosi03's Avatar
That setup is crazy
The IC air duct looks like it will make a good heat sink as well.
Q. Did you consider pulse timming of each runner for the mani design?
I noticed the alternating sequence between the two outlets (3,2:1,4), but my question is regarding the runner lenghts. I'd like to know if there's a benifit to having lenghts such that pulse 1 and 3 arrive to divided outlet same time during RPM (at peak torque or something)... Basically any wave theory applied to choosing runner lenghts?
Old Apr 4, 2007 | 02:02 PM
Teglove2's Avatar
Well.......obviously i have 1/4 on one side and 2/3 going in on the other, hence dividing firing cylinders. As far as runner length i try and use the same amount of bends on 1/4 and 2/3 using as much straight as possible. But easier said than done trying to fit a gt42 and not copy another design!! I absolutely will not use any elses ideas on my products. So....i did what i could and i couldnt be happier with the results. Its almost done welding so ill post em up when its done...Thanks for the compliments guys i take a lot of pride in my work!
Rest of the setup included mazworx cams, fully ported head, victor x, bdl 74mm tb, 4" dp, twin 38mm gates, 1000's, and aem. Once i get the suspension on and the car tuned on this setup Ill be getting the fuel system next, whoot!!
Ryan
Old Apr 4, 2007 | 02:08 PM
MidShipCivic's Avatar
Default Re: (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">That setup is crazy
I noticed the alternating sequence between the two outlets (3,2:1,4), but my question is regarding the runner lenghts. I'd like to know if there's a benifit to having lenghts such that pulse 1 and 3 arrive to divided outlet same time during RPM (at peak torque or something)... Basically any wave theory applied to choosing runner lenghts? </TD></TR></TABLE>
Pulse arriving at the same time? This shouldn't be happening.
That duct probably follows the border of the bumper opening.
Old Apr 4, 2007 | 02:45 PM
turbosi03's Avatar
Default Re: (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Well they could... Pulses are so close together anyway at high rpm. I was thinking if you set runners so that during certain rpm range they create constructive interference where velocity increases at the pulse. May not be practical since this would result in less pulses over time.
I have no experience in manifold design, just wanted to learn how much is concideration of theory Vs application challanges such as trying to fit a gt42 while using least amount of bends, etc...
Old Apr 4, 2007 | 08:08 PM
vsmhatched's Avatar
very nice
Old Apr 5, 2007 | 08:53 AM
Agtronic's Avatar
That turbo is hilarious. In my world, a 57 trim is huge ...
Beautiful work by the way.
Old Apr 5, 2007 | 09:21 AM
JG-Fabrications's Avatar
Default Re: (Teglove2)
Good luck with not copying anyone in any situation as as soon as you think you have something original you still copied the idea of putting the turbo on top
-James
Old Apr 5, 2007 | 10:11 AM
Teglove2's Avatar
lol.......obviously. But thanks for the thumbs up guys. Will be posting final pics tonight.
Ryan
Old Apr 5, 2007 | 10:14 AM
3minburnout's Avatar
is this manifold backpurged?
Old Apr 5, 2007 | 10:23 AM
*Boostwerks*'s Avatar
So, how is the turbo going to clear the hood?
Teglove2's Avatar
Not this one, its my personal manifold. All the rest of my manifolds that i have on order will be backpurged i just finished the setup last night. I work for a manifold company now, cant say who tho, and i belive we are the one of VERY few companys with absolutely no comebacks. Besides in the last 3 shops ive worked at ive only seen wastegates crack, not runners...but like i said we've never had one problem. The head flange is welded front/back and collector is welded in/out......
Ryan
Modified by Teglove2 at 6:18 PM 4/5/2007
Old Apr 5, 2007 | 10:26 AM
Teglove2's Avatar
Boostwerks.......to answer your ?'s.
First of all my buddy took that pic before i lowered the turbo onto the flange lol, it clears just fine. And i DO add filler parallel, im not a newb to welding. I was just tacking....
Ryan
Old Apr 5, 2007 | 10:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote">Boostwerks.......to answer your ?'s.
Ryan</TD></TR></TABLE>
Coo. I figured as much after looking at the pics again...hence why I deleted the question...
BTW, do you weld the runner's on or off the manifold? Just curious.
Old Apr 5, 2007 | 10:39 AM
Teglove2's Avatar
def off the fixture!
Old Apr 5, 2007 | 01:20 PM
berts95ej's Avatar
* B A N N E D *
pretty sweet mang, look forward to seeing the finished product.
and when is your car hitting the streets again? im gonna go ahead and set a deadline so you stop fooling around and get something done... you have till april 7th... good luck
Old Apr 5, 2007 | 02:09 PM
Teglove2's Avatar
I'm hoping its done in the next 2 months. Im working on it every night but its taking time and $, which i dont have lol. It will be done by the hondatech/ohiohondas meet at slowmotion in june i believe it is....
Old Apr 5, 2007 | 02:49 PM
jj07's Avatar
OG Fabricator
top mount divided manifold + GT42R = new rice
J/K good work ryan nice to see you putting out new stuff
Old Apr 5, 2007 | 02:56 PM
Teglove2's Avatar
lol.......there you are jon! thx bro
Old Apr 5, 2007 | 03:23 PM
on the finished product
