Jdm H22A Oil
Whats going on guys i just wanted to know if i was using the right oil in my car, it has a Jdm H22a with 27XXX miles, right now it doesn't burn any oil between oil changes and im using 5w 30, is this correct? thanks
Btw, here is the Castrol 0w-30 that i am referring to, also affectionately known as "German Castrol" (GC):
http://theoildrop.server101.co...UBB51
The oil forums have dedicated a section to this green oil that smells like gummy bears :D Check out the stickies in that forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB2H22 »</TD></TR><TR><TD CLASS="quote">You turds, someone needs to introduce you to Royal Purple.</TD></TR></TABLE>
Royal Purple 5w30 for me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redtop22 »</TD></TR><TR><TD CLASS="quote">
X's 2!
</TD></TR></TABLE>X's 2!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc »</TD></TR><TR><TD CLASS="quote">Whats going on guys i just wanted to know if i was using the right oil in my car, it has a Jdm H22a with 27XXX miles, right now it doesn't burn any oil between oil changes and im using 5w 30, is this correct? thanks</TD></TR></TABLE>
according to helms, yes, you are using the right oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigirb2002 »</TD></TR><TR><TD CLASS="quote">i use 5w30 amsoil synthetic 35k motor</TD></TR></TABLE>
good oil
i found out not to long ago that my local NAPA stocks amsoil
good oil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">0-W20 mobile one syntec for me
Will 20 give you enough heat protection?
</TD></TR></TABLE>Will 20 give you enough heat protection?
suppose to work better for honda's
works great for me and it doesn't burn off as much.
been using it for years and i am using it in my current h23vtec. switched to it from torco sr5 5-w30 after about 1500 miles.
so far i have 4,200 miles
