Suspension & Brakes Theory, alignment, spring rates....
Brake question regarding bleeding...
Old Apr 4, 2007 | 04:48 AM
Mr. Vapor's Avatar
Default Brake question regarding bleeding...
'03 Accord LX Coupe V6
Took off the front calipers to clean them up a bit, replaced rotors and pads. obviously I'll need to bleed the fronts. Im assuming I need to bleed the rears now too since there is only one Master Cyl for the entire brake system.
Just looking for a quick confirmation.
Old Apr 4, 2007 | 07:34 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Brake question regarding bleeding... (Mr. Vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor &raquo;</TD></TR><TR><TD CLASS="quote">'03 Accord LX Coupe V6
Just looking for a quick confirmation. </TD></TR></TABLE>
If you only took the front calipers off and not the master cylinder, then you shouldn't have to worry about bleeding the rears. There is a gas-trap (like a toilet) in the pipes where the brake soft lines connect to the hard lines. This helps keep the air from going up the pipes if the lines are opened.
Just bleed the fronts, and make sure the brakes function like normal...
Teazet
Oct 15, 2012 05:30 AM
pimpdd101
Nov 29, 2008 09:08 PM
drewski101
10
Aug 17, 2008 06:21 AM
tazz29
Jul 9, 2008 10:52 AM
prettysharpladi
May 28, 2005 05:52 PM
