2003 accord coupe brake issues...
Hello. I'm having problems with my brakes on my 2003 accord coupe. The symptoms is similar to the master brake cylinder going bad where the brake pedal goes to the floor. I replaced the master brake and within a month I had the same symptoms. I took my car for a brake inspection and ended up replacing the pads, rotors, calipers, master cylinder on my own. Within a month the symptoms came back. If I was to slam on my brakes, I would hear a grinding thumping noise. I took it for a second brake inspection and was told it was the master cylinder again. I have replaced the master cylinder 3 times and end up with the same problem each time and no one seem to have an answer. Can someone PLEASE help me with my problem?
Re: 2003 accord coupe brake issues...
sounds like a bad abs modulator, there was a tsb on it, they pull in air, the only fix is to replace the modulatior unit, unlike the oddesys and elements that have a fix/recall available
scubacamper
11-03-2013 09:43 AM
JZA70
11-14-2006 11:16 AM
