b16 distributor question
Old Apr 3, 2007 | 07:02 PM
blackcrx16's Avatar
Default b16 distributor question
would a ls distributor work on a b16. i got a b16 and i spent some money putting it in a eg but now im low on money and i need a distributor to put on, i have a ls sitting here out of a 2000 teggy ls. some one told me i have to cut one of the bolt legs to get it on. please help would a obd 2 work on an obd1 ecu or what?
Old Apr 3, 2007 | 07:05 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Yea it will work if you cut the legs, but i dont know if you can set the timming correctly. All you nead to do it cut the plug and wire everything correctly an it will work, I THINK?
Old Apr 3, 2007 | 07:07 PM
Ow it will work because i have a B16 dist.. in my obd2 gsr with a obd1 ecu
Old Apr 3, 2007 | 07:19 PM
blackcrx16's Avatar
Default Re: b16 distributor question (blackcrx16)
will it just plug in and work? no rewire?
Old Apr 3, 2007 | 07:22 PM
NVMYSTI's Avatar
The OBD2 and OBD1 distributor clips are different and need to be changed in order to plug it in
Old Apr 3, 2007 | 07:28 PM
Didnt he said the has a 2000 ls wich is obd2 an a b16 wich is obd2. what year is the b16?
Old Apr 3, 2007 | 07:32 PM
blackcrx16's Avatar
Default Re: (phyzJunkieCivic)
i have a 1992 eg with a b16a in it. i have a 2000 ls distributor
Old Apr 3, 2007 | 07:55 PM
is b16a obd1 or two?
Old Apr 4, 2007 | 02:07 PM
blackcrx16's Avatar
b16 a is a obd0 but i converted it to obd1. the car is a 1992 vx. i have a single cam distributor running the engine now but its not mounted properly but the engine runs fine and i can move it enough to set the timing.
Damills
Feb 4, 2007 10:59 PM
jccrxtuner916
Oct 16, 2005 12:23 AM
honda011
Jun 10, 2005 09:03 AM
