Check Engine Help. Plz! Kthnxxxx
Old Apr 3, 2007 | 06:32 PM
Boosted_Rex.'s Avatar
Default Check Engine Help. Plz! Kthnxxxx
I have a 89 Honda Crx Si (Converted over to OBD1) Im running a LS-T setup and I just recently installed a 99-00 Si Cluster (Along with the electronic VSS) and my check engine light has been turning on since....It never turned on when i had the old cluster I mean it did but like only when auxillary power was on...but once cranked it was off. I also noticed that the check engine only comes on when the car is warm.
I just wanna know how to jump the code? I dont have the side connector like my friends 90 Crx Si....any help would be greatly appreicated.
Old Apr 3, 2007 | 11:45 PM
EF_LSVtec's Avatar
Default Re: Check Engine Help. Plz! Kthnxxxx (Jspek_Rex)
what was the code?
Old Apr 4, 2007 | 02:47 AM
janz3n's Avatar
Default Re: Check Engine Help. Plz! Kthnxxxx (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">what was the code?</TD></TR></TABLE> holy crap,, try reading a bit
you can use a paper clip so i have heard.
Old Apr 4, 2007 | 05:25 AM
ludesrv's Avatar
You have a blue 2 pin plug that you can jump and will start flashing the code on the cluster.
It's in the dash under the passenger side by the door. Look hard for it, it IS there. If you don't find it, then that's your problem. Without us knowing the code you might aswell replace everything cause that's the only solution.
I wish people knew more about there own cars...
robcivic559
May 20, 2009 12:34 PM
yellowjdmcrx
Oct 25, 2005 09:08 PM
Mach69
Jun 3, 2005 06:50 PM
SOHC_Brian
Mar 25, 2004 12:14 PM
CivicHB91
Sep 10, 2002 06:43 PM
