pilot bearing?
Old Apr 3, 2007 | 05:21 PM
HondaRexBoi's Avatar
From: IN YOUR BASEMENT, ON YOUR COMPUTER, minesota, united states
Default pilot bearing?
im doing a b16a swap into my crx, i have an ls tranny that im going to use for the swap.
i figured out on my own how to replace the T.O bearing but know i have a pilot bearing problem. it looks like i can fit it into my fly wheel ( 8lbs fidanza). do i insert the bearing in the fly wheel then put the flywheel on the motor, or do i put the bearing on the motor then put the flywheel on?
thanks ahead of time.
Old Apr 3, 2007 | 05:25 PM
cbp_crx's Avatar
Default Re: pilot bearing? (HondaRexBoi)
put it into the flywheel.
Old Apr 3, 2007 | 05:26 PM
Default Re: pilot bearing? (cbp_crx)
there isnt going to be any messing around when i put it on the motor is there
Old Apr 3, 2007 | 05:28 PM
abnaasefmb's Avatar
the only way you should be able to do it is the put the bearing in first. it need to be seated, if you look you will see a little lip that the bearing sits on, also the bearing will not sit flush, it will stick out a bit so don't beat the hell out of it trying to get it flush.
cbp_crx's Avatar
no everything will be ok, that is how honda says to do it, what you want to do tho, is get a socket about the same size as the bearing and you use the socket to tap it into the flywheel, so you dont risk damaging it.
Old Apr 3, 2007 | 05:33 PM
thanks guys really appreciate it.
Old Apr 3, 2007 | 05:36 PM
wait.......... do i really even need it?
because when i pulled the tranny of the integra motor, i took of the fly wheel and i didnt see any thing that looked like a pilot bearing any were in sight.
ricky529
Jun 19, 2011 11:59 PM
dacrxguy
Aug 3, 2009 09:37 PM
f22pwrdaccord
Feb 9, 2006 05:36 PM
1fastVX
Aug 22, 2002 05:43 PM
