LS Vtec opinions
Old Apr 3, 2007 | 04:45 PM
Dev15Bizz's Avatar
Default LS Vtec opinions
im doin ls vtec b18b block b16 head, p30 pistons, some sort of cams prolly skunk 2 stage 2, hondata, itr header.... any suggestions on a brand for the head gasket? heard good things about cometic but just wondering
Old Apr 3, 2007 | 04:48 PM
Suck my DX's Avatar
Default Re: LS Vtec opinions (Dev15Bizz)
why not oem?
Old Apr 3, 2007 | 04:56 PM
kpowerdhatch's Avatar
oem
Old Apr 3, 2007 | 06:27 PM
skiracer8148's Avatar
cometic makes a special gasket for ls/vtec,i used it!
Old Apr 3, 2007 | 06:41 PM
crxowner's Avatar
Golden Eagle, they use an oem one but modify it to fit the dowel pins and it comes with the kit when you order it
Old Apr 12, 2007 | 07:19 PM
B18c192DA's Avatar
I would probably go cometic...i have heard good things, specially if you are goin over 11-1 compression
Old Apr 12, 2007 | 07:49 PM
EGhatch87's Avatar
i used a cometic on my LS/VTEC with P30 pistons and had no problems
Old Apr 12, 2007 | 08:45 PM
CE1's Avatar
CE1
fel-pro
Modified by nonvtecek9 at 12:15 AM 4/16/2007
Old Apr 12, 2007 | 08:47 PM
Jay_Sensing's Avatar
Default Re: LS Vtec opinions (B18c192DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c192DA &raquo;</TD></TR><TR><TD CLASS="quote">I would probably go cometic...i have heard good things, specially if you are goin over 11-1 compression</TD></TR></TABLE>
Huh, my car is a bit over 13.3 static and I use OEM. Wonder why that is?
Old Apr 12, 2007 | 09:03 PM
TwinOptiX's Avatar
OEM... I use it on my ls/vtec and I have no problems. 12K on the motor after 5 HPDE's last year and alot of drag racing.
Trust in Honda!
wernhersey
29
Jan 6, 2007 02:45 PM
rondigs
Mar 18, 2005 10:15 AM
b18vtek
Dec 5, 2004 07:01 PM
AGGRESSIVEDA9
Nov 13, 2003 05:24 AM
