mini-me rough idle
Old Apr 3, 2007 | 04:10 PM
4dohs4mohoes's Avatar
Default mini-me rough idle
d15b7 block, z6 head. New TB, Head gasket, plugs, wires, cap, rotor. ect.
At idle(750-800) it runs super rough, shaking and misfire sound. It smooths out around 1100 or so. Im also getting a CEL, code 41, which I know is the O2 heater. Would that have anything to do with it? This is kinda annoying.
TIA
Old Apr 3, 2007 | 04:23 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: mini-me rough idle (boo bees)
I think this is the 1,014th post about surging idle today.
I think to get your answer you probably won't even need to do an archived search.
Really, searching for "surging idle" in the search index should pull up almost 200 results.
Old Apr 3, 2007 | 04:40 PM
Default Re: mini-me rough idle (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">I think this is the 1,014th post about surging idle today.
Really, searching for "surging idle" in the search index should pull up almost 200 results.</TD></TR></TABLE>
No need to be smart. And FYI its not a surge. If you read the OP you would see I tried to explain it as a misfire. But it smooths out around 1100 when I open the throttle.
Once again TIA
Old Apr 3, 2007 | 06:18 PM
ghettoSi's Avatar
she's cheating on you
SEARCH FTMFW!!! Wow people its the red button in the top right corner of your screen. It works miracles I swear!
Old Apr 3, 2007 | 06:22 PM
Default Re: mini-me rough idle (ghettoSi)
okay I kinda feel like a jack ***. I did a more extensive search and maybe found the problem. And BTW, the search function is what I mostly use on this site. Dang sorry.
Old Apr 3, 2007 | 06:23 PM
ghettoSi's Avatar
shoklid
Oct 19, 2009 07:03 AM
hondaEg_808
Mar 18, 2008 04:05 AM
spcrxracer
Sep 10, 2004 05:15 AM
6thgen4u2nv
11
Jan 11, 2004 03:19 PM
89 CRX SI
Dec 14, 2002 05:35 PM
