Crank Angle Code?
I have a brand new distributor, anywhere else this codes in from? i have a 91 SI hatchback, obd1, jdm p30, rywire kit..
thnks in advance
thnks in advance
Check continuity of your wires from the dizzy to the ecu. Then check the same wires with a body ground for continuity. These steps are free and take minutes to do. At that point, change the dizzy with a known working one. Then change the ECU. If the problem persists at that point, you are fucked cause there is nothing else you can do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 »</TD></TR><TR><TD CLASS="quote">Tried a obd1 GSr ecu and same ****, </TD></TR></TABLE>
Did you check your wires, that's the last possible option. Download the 92-95 civic manual and follow there steps to check the wiring. I did it and caught my own wiring mistake. Fried my ECU and dizzy before I caught it tho.
Everything was fine, then I had to replace a tranny bearing. Did that, and changed my dizzy which was working, but one mounting ear was removed. So I just wanted the one for my car, and now this, Tried a new dizzy too and same ****..
ivanson
Dec 4, 2005 12:35 PM
