FS:benson sleeve, eagle rods,built b16 head,wideband, greddy bov, ramhorn, sc61, wastegate, injector
updated with new lower price
if the item is not listed anymore that means its been sold
<FONT SIZE="18"><u>everything listed is the pick up price unless stated</u></FONT>. shipping will range from 10-25 depending on the size of the item. the bottem end will be $100 or so for shipping due to weight.
paying with paypal please add $0.25+3% or if you dont want to pay the fees. i take cash...
if you want something or have a question. you can pm me here or aol aim me at sheryip6786
benson sleeve 83mm 1.9L b18b block
-water tube
-water pump
-oil pump
-oil pan
-oil pick up tube
-oil windage tray
-balance and polished crankshaft
all with 7000miles, recommend a hone or bore to 84. blew my headgasket so coolant got into the cylinder walls. washed it down a little. so thats why i recommend a hone or bore to 84
$1050 picked up or $1200 shipped east coast for west coast you looking to spend a little more for shipping pm for quotes with your zip code
B18a/b or B20 eagle rods/83mm cp 9.1 pistons for gsr head- $400 if used with b16 head on a b18 motor its like 8.9
golden eagle gsr headstuds - $80
b16 or ITR AEBS intake manifold complete with sensor and tb -$ 120
hondata intake manifold gasket - $20
haspot b series eg mounts - $300
Motor mount inserts both upper and rear for eg hatch b series - $25
RLD ramhorn manifold t3 flange w/ 3" 4bolt downpipe and dumptube - 725
the downpipe has a slight dent near the bend also theres a 3bolt flange welded on it. will take new pics once i get the car on the lift this weekend
Spoolin 92-00 civic also fits integras- CNC BENT POWDERCOATED FMIC PIPING 2 inch turbo to FMIC and 2.5 fmic to Throttle body comes with all the coupers and clamps- $250
greddy type s bov(real thing) - $150
greddy daul stage EBC - $150
tial 38mm silver wastegate 1bar spring- $150
Oil Pressure gauge , vaccum/boost 20psi sports comp autometer gauge- $30ship each
tri pillar pod gray for eg hatch probably fits others in the 92 95 civic- $15
3" exhaust for eg hatch with mangaflow muffler. does require to cut the bumper a little - $250 will not ship unless you allow me to cut the b pipe so it shorten up the pipe or pay $100 in shipping fee due to over size box
AEM wideband ugeo whwatever it is - $200
Modified by komat at 4:04 PM 4/9/2007
Modified by komat at 4:46 PM 4/9/2007
Modified by komat at 9:40 PM 4/9/2007
-water tube
-water pump
-oil pump
-oil pan
-oil pick up tube
-oil windage tray
