Transmission Mount
Old Apr 3, 2007 | 01:15 PM
phazeone's Avatar
Default motor sitting at an angle...
so driving down my street today and the car started to sound funny. I do a walk around of the car and notice nothing bad. when i look under the car i noticed my exhaust had snapped off at the cat and i firgure that, thats whats been making the noise right? WRONG i try to back onto my drive way and cant seem to move anymore. i try again and all i get is high revving. so i look under my motor to find my motor is sitting sidways...and look on the passenger side mount and notice the bolt had come out..so now my axle came out on the passenger side and 3 bearings came out..anyone wanna help me out? i just purchased the car a couple weeks ago aswell. thanks! i will post up pics in a bit.
Modified by phazeone at 3:02 PM 4/3/2007
Old Apr 3, 2007 | 03:06 PM
janz3n's Avatar
Default Re: Transmission Mount (phazeone)
holy crap.. please tell me all the mounts came off not just one?
Old Apr 3, 2007 | 04:04 PM
VtecSyndrome's Avatar
Default Re: motor sitting at an angle... (phazeone)
W/o seeing the mount it's hard to see if putting a new bolt in will be the only fix it needs. if there is no other damage to anything else (other than what's mentioned) then all you need to do is jack up the tranny to take the load off the mount and take that thing out to inspect it for damage. You have to take out the battery and remove a few other things to make the mount accessible but it's really easy to do
Those bearings are from your inner axle joint and can probably be reused, as long as there is no gouges in them. if you have never messed w/ axles just take it out and to a shop and they can reinstall those bearings in a snap. if there are damaged then just buy a new axle from autozone for $50.00 and use your messed up one for the core. simple
I am curious how your motor mount came apart though? what brand is it?
Old Apr 3, 2007 | 05:23 PM
phazeone's Avatar
Default Re: motor sitting at an angle... (VtecSyndrome)
well from the looks of it it looks like the axle popped of nothing damaged though. and for the mounts. there stock ef mounts. any suggestions on how to upgrade on that? annd the previous owner chopped the springs. whatta no no. so bouncy. but it'll be on the road in no time. oh and the bolt looks like it just came loose. im not driving the car until i tighten and triple check everything.
and would i just put the jack under the tranny and lift. just cause my car is low and the jack can barely go under the car itself. annd last any step by step info on how to re-install the axle??
Old Apr 3, 2007 | 09:30 PM
rexracer626's Avatar
haha the same thing happend to me exept my mount ripped off man i went through 3 tranny mounts on dohc zc but yea the same exact thing happened to me the axle popped out the boot tore but it was all good got a homie at autozone to hook it up haha
Old Apr 4, 2007 | 11:38 AM
phazeone's Avatar
Default Re: motor sitting at an angle... (rexracer626)
so with those 3 bearings that came off the axle would i just snap them back on? annd would i be able to use a stock ef mount to replace the broken tranny mount? DOHC ZC motor by the way.
Old Apr 4, 2007 | 11:56 AM
89efDUSTY's Avatar
that is scary...when i get home im checking all my mounts
Old Apr 4, 2007 | 12:34 PM
e jay one's Avatar
Default Re: motor sitting at an angle... (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phazeone &raquo;</TD></TR><TR><TD CLASS="quote">so with those 3 bearings that came off the axle would i just snap them back on? annd would i be able to use a stock ef mount to replace the broken tranny mount? DOHC ZC motor by the way. </TD></TR></TABLE>
no you need a new axle. axles are super easy to replace though 15 minute job. get it at autozone they got life time warranty. and yea just get stock ef mounts the douche bag that sold you the car probably forgot to tighten them all the way.
Old Apr 4, 2007 | 12:54 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: motor sitting at an angle... (e jay one)
Maybe this is why you are supposed to replace the bolts for the mounts after you remove them.
Old Apr 4, 2007 | 05:24 PM
Default Re: motor sitting at an angle... (ILcrxsi1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe this is why you are supposed to replace the bolts for the mounts after you remove them.</TD></TR></TABLE>
I've never heard that before?? Head bolts yeas but not motor mount bolts??? I have always reused motor mount bolts and NEVER had a problem. You just make sure everything is tight, I've done so many motor swaps that I've lost count and again, no problems w/ mounts..........ever.
Old Apr 4, 2007 | 07:36 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">
I've never heard that before?? Head bolts yeas but not motor mount bolts??? I have always reused motor mount bolts and NEVER had a problem. You just make sure everything is tight, I've done so many motor swaps that I've lost count and again, no problems w/ mounts..........ever.</TD></TR></TABLE>me neither but check the service manual. It clearly says "if removed, replace"
sirhavok
19
Aug 27, 2007 10:04 PM
laserspeeddemon
May 3, 2007 10:55 PM
DonPapadapolis
Apr 24, 2004 04:06 PM
Mr.Saturn
Feb 19, 2004 11:13 AM
