leaking oil.
Old Apr 3, 2007 | 01:02 PM
Lauj87's Avatar
Default leaking oil.
Alright guys heres the situation with my car. right now it's leaking oil like a bitch. when the headers get hot and oil starts to drip on it it smokes like a ****, every person i pull up next to rolls down there window tells me... Sir..your car is smoking lol. The leak can be comming from either 1 of two places or even both.
1. Typical cam seal leak.
2. Oil pan gasket leak.
Im leaning more towards the cam seals because i can see some oil trailing form the cams. but then agin theres oil all over my oil pan. Not to mention im not losing much oil either about a quart every 2500 miles.
Anyone else have this issue?
Old Apr 3, 2007 | 01:59 PM
Perfectionist's Avatar
Default Re: leaking oil. (Lauj87)
Obviously, you need to determine where the leak is coming from and then correct the problem. Oil on the pan doesn't necessarily mean anything because the oil will run down there from somwhere above.
Old Apr 3, 2007 | 03:32 PM
Lauj87's Avatar
bump* anyone else?
Old Apr 3, 2007 | 03:50 PM
JDM-EJ1's Avatar
Default Re: leaking oil. (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Obviously, you need to determine where the leak is coming from and then correct the problem. Oil on the pan doesn't necessarily mean anything because the oil will run down there from somwhere above.</TD></TR></TABLE>
Correct. When I had this problem ('87 Accord) it was a bad valve cover gasket.
Old Apr 3, 2007 | 05:12 PM
Lauj87's Avatar
I've already replaced my valve cover gasket. still no fix on it.
Old Apr 3, 2007 | 07:02 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (Lauj87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">I've already replaced my valve cover gasket. still no fix on it.</TD></TR></TABLE>
So do both in one day noob
New cam seal, and oilpan gasket from the dealer will be around $30 give, or take.
All you need to do for the cam seal is remove the valvecover,
and the One camcap where the seal is.
Oilpan is also an easy one to get off, remove the inspection cover on the bottom of the trans,
then the rest of the 10mm bolts/nuts holding the pan on,
I'm almost thinking you can take the pan off without removing your header too.
Old Apr 3, 2007 | 07:09 PM
Lauj87's Avatar
Default Re: (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">
I'm almost thinking you can take the pan off without removing your header too.</TD></TR></TABLE>
Lol i didn't say i didn't know how to do it...im just too damn lazy
Old Apr 3, 2007 | 07:18 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">Lol i didn't say i didn't know how to do it...im just too damn lazy </TD></TR></TABLE>
Hahah, well .. I guess you're out of luck then.
Get some pics of the spots you think it is, I could give you a better idea of what exactly is there that could be replaced.
Old Apr 3, 2007 | 08:27 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">I'm almost thinking you can take the pan off without removing your header too.</TD></TR></TABLE>
Probably. But it's 10x easier if you take off the header; espically if you have a two peice header; just remove the second half.
Old Apr 4, 2007 | 07:38 PM
Lauj87's Avatar
Default Re: (JDM-EJ1)
bump!*
Old Apr 4, 2007 | 07:50 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lauj87 &raquo;</TD></TR><TR><TD CLASS="quote">bump!*</TD></TR></TABLE>
For what? We already told you what to look for.
MumBleZ_94gsR
May 30, 2009 03:26 PM
xTimmyx
Mar 7, 2008 10:21 PM
tw1nny03
Mar 3, 2008 05:29 AM
liquidx
Mar 18, 2007 04:14 PM
DAintegraGSR
Apr 28, 2005 08:22 PM
