Supertech Valves on Daily Driven Motor - Recommended or Not?
Supertech Valves are proven durable and to perform in race engines, but are they just as safe to run in a daily driven motor? Its usually safe to assume that any component strong enough to handle race type conditions should be more than enough for a motor which will not see such extremes on every start of the engine.
Does anyone have any opinions whether or not its recommended to run Supertech Valves on a DD? Is durability and longevity a factor at all in comparison to OEM Honda valves, or will they last as long, if not longer, than OEM? Are there any concerns with using Supertech on an everyday commuter?
Supertech Valves are great in race and street motors. Theyre good for long term use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">Supertech Valves are great in race and street motors. Theyre good for long term use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng »</TD></TR><TR><TD CLASS="quote">good for either application. </TD></TR></TABLE>
Perfect, thanks for the responses guys.
Anyone else with any input in this topic?
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng »</TD></TR><TR><TD CLASS="quote">good for either application. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">These are what I am buying when I go to purchase valves.
I say go for it.</TD></TR></TABLE>
sauceja-if you dont mind me asking, are you choosing flat faced or dished valves?
gsr block, p30 pistons (from h-motors) flat faced black nitride, type r head
Looking to run into the high 11:1 ratios goal is 12:1 but if I fall short thats fine. I am running oem HG and no resurfacing of block or head.
Most likely sell the motor after I get it running. Got the h2b bug in me.
EnjoyTheRideDC2
18
Apr 6, 2007 09:31 PM
Boostage
Sep 19, 2005 08:32 PM
