Rexman's Incerdible Blowout Sale! WOW WOW WOW
Old Apr 3, 2007 | 06:12 AM
rexman's Avatar
Default Rexman's Incerdible Blowout Sale! WOW WOW WOW
I'm Paypal Verified and can provide Vouches.
Prices do not include s/h unless stated.
Shipping quotes are for the lower 48
states and do not include international s/h rates.
<u>K Prepped 1990 CRX Si Rolling Chassis $3499</u>
-Over $1800 in OEM Honda Parts Reciepts.
-Needs L.Fr.horn (frame) pulled slightly, easy fix, (see pics)
<u> Includes:</u>
- Hasport K-series mounts
- Full Exhaust System - Sigma Six Racing header (4-2-1), ceramic coated by SwainTech, modified 3" Thermal Research Development Stainless Catback w/ Catco hi flow Cat and custom Stainless Borla Twin tips. - Stainless Straight pipe also included.
- Brand new oem fr. core support, usdm front bumper, and headlights.
- Full Race radius arms, needs new fr. bar (see pics)
- jdm fenders w/ sidemarkers
- 15/16th brake master cylinder
- Tinted tail lights
- Stock suspension and stock brakes
Not shown in pics but also included:
- Interior carpet and console
- Brand new rear bumper support, fr. door seals, r.qtr. seals, and hatch top trim, plus numerous other new oem trim parts...
- Walbro High Output 255lph fuel pump (installed 5k ago)
- will come with steelies
<u>Resprayed oem barbados yellow (Y-49) by Volkers Auto Body</u>
- Shaved antenna, roof pisser, and rear wiper arm
- Fully functional, painted carbon fiber sunroof that will never rust!
<u>Chassis Prep by Domination Chassis</u>
- welded in Hasport mount
- Recessed floor for shift box
- Rear Crossmember mod
- TRD Turbo 3" Exh. mods
<u>Build thread here:</u>
http://www.k20a.org/forum/showthread.php?t=20812
<u>youtube dyno pull @ Evan's Tuning</u>
<u>Also For Sale...</u>
- K20A2 Type S 35k $2999
<u>Includes:</u> Starter, Alternator, Intake manifold, throttle body, fuel rail, and injectors. New Denso Iridium Plugs IK22#531 -Less than 5k
-RSX Type S 6spd Transmission w/LSD Quaife installed (5k ago) $1999
- Hasport Axles $249
- Aeromotive Fuel psi Regulator $75
- Alternator $69
- Starter $69
- Hasport Stage 1 EF K20 Axles $249 -Less than 5k
- Denso Primary Oxygen Sensor $199 -Less than 5k
- Hondata Intake Manifold Gasket $29
- Golden Eagle Fuel Rail $75
- Aeromotive Fuel PSI Regulator $75
- Russell Stainless and Braided Fuel Hose ALL $25
- Russell A/N Fittings ALL $75
- Full Race Radiator (EG half size) $99
- Spoon Thermostat $39
- Spoon Magnetic Drain Plugs $25
- Mfactory Magnetic Drain Plugs $25
JDM WATANABE Wheels 15x6.5 $799
<u>1999 JDM Spec-R Cluster</u> $149
<u>Ported JDM Spec-R Intake manifold</u> $149
<u>RPM Services 70mm Throttle body</u> $199 shipped
- includes Map Sensor, TPS Sensor & gasket.
Type R Thermostat Housing, Thermostat and Temp. Sensor $39 shipped
Corbeau Seat Bracket (for 88 CRX) $49
<u>Tokico Illumina's for 88 EF</u> $269 Brand New!
<u>Brand New Quaife LSD for B series</u> $799 Shipped!
K20 Type R Crank pulley $39
Redline Oil $4 each (2qts)
Intake manifold Cover $15
Intake Manifold Gasket $7 Shipped
RSX Type S Immobolizer with Key and Keyfob $99
OEM Type S Denso Iridium Spark Plugs Set of 4 (30K) $20
Fuel Rail $10 - needs flared
Engine Mounts
- Side $ 30
- Rear $ 25
Exhaust manifold & heatshield $39
Cat $80
A/C Compressor $99
Power Steering Pump $69
D Series
- Starters $49
- Alternator for b series swap (3 rib pulley) $49
- Distributors
- obd0 $49 each
- 8-pin $49
1988 only D Series Axles
- Drivers side $30
- Pass. side $30
Rear Trailing Arms (88-91 FWD) Civic $99
Manual Pedal Assy. <u>Must for 5spd swap!</u> (all 88-91 Civic) $15
Hatch Rear Deck Assy. $15
Rear Hatch Tailights $30
EF9 JDM License Plate $9
Samco Silicone Hose Kit $99 shipped
- D series (black 10pcs.)
EF Cooling and A/C Fans $9 each
[b]Toyo Proxes RA1 205/50ZR15 (X4) $550 SHIPPED
CRX JDM Corner light LH $15
EF Corner and Bumper lights
1. 88-89 CRX RH $10
2. 88-89 Hatch LH $10
3. EG RH $10
4. 90-91 CRX LH $10
5. 88-89 EF Turn signals (Set)-sold
Hatch std. Wing $15
EF Battery Tray $10
EF Throttle Cable & Transmission Cable $15 each
d16 dpfi Throttle body $9
d Series Intake Elbow $5
CRX Rear Wiper Motor $9
D Series Jackson Racing Supercharger Drivebelt $9
Craftsman Sander/Polisher $19 shipped
Initial D Collection
Initial D DVD
- Battle:01 Akina's Downhill Specialist $9
Initial D Manga
- Vol.2 $4
- Vol.4 $4
Initial D Series Collection DVD Box Set $49
10 Disc Set Episodes 1-26
Fujimi Drift King AE86 $10
Series 3 - 1/24th scale
Option Video - Vol.70 $9 shipped
Rare Fujimi and Tamiya Nissan Models!
1. R33 GT-R Skyline $ 35 Shipped
2. R33 GT-R V-Spec Skyline $25 Shipped
3. R34 GT-R Skyline $ 25 Shipped
4. Kure-Nismo GT-R Skyline $35 Shipped
5. 180SX $ 45 Shipped
Brand new BMW Mini Pajamas $19 Shipped
- Medium Size
Computer Board Mousepad $10 Shipped
- Sold
- d series alternator -sold to george34 on crxcommunity.
- Exedy Clutch -sold to ne3ek on k20a.org
- Engine harness -sold to ne3ek
- K Pro PRB ECU -sold to ne3ek
- Rywire EF K20 harness -sold to ne3ek
- Half Shaft -sold to ne3ek
- Shift Cables and Shift Box -sold to ne3ek
- Domination Chassis Cold Air Intake -sold to ne3ek
- Password Hood Dampers -sold to ne3ek
- Centercaps -sold to SIR-Rocket
- VTEC Solenoid Gasket -sold to SIR-Rocket
- Secondary Oxygen Sensor - sold to JFX from k20a.org
- ITR Titanium Shift **** -sold
- Kamikaze Header (b series, 2.5" diam.) -sold to Alex
- Y1 Cable Transmission -sold to Alex
- Mfactory Oil Cooler Kit - sold to fermatta77 on k20a.org
- Clutch Slave Cylinder -sold to fermatta77
- RSX Throttle Cable - sold to fermatta77
- AEM Underdrive Pulley - sold to Signalpuke on k20a.org
- Hasport Mounts (b series) -sold
- EF Civic hatch center console -sold to kuniEF
- EF Sunroof deflector -sold to Smokinsax
Modified by rexman at 11:19 PM 5/7/2008
Old Apr 3, 2007 | 07:04 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: Rexman's Incerdible Blowout Sale! WOW WOW WOW (rexman)
nice ish bro
Old Apr 4, 2007 | 09:47 AM
RedShiftChris's Avatar
Default Re: Rexman's Incerdible Blowout Sale! WOW WOW WOW (Mr.OB*GYN_Rhett)
I'd like the D16A6. PM sent.
Chris at RedShift
Old Apr 5, 2007 | 05:42 AM
rexman's Avatar
Default Re: Rexman's Incerdible Blowout Sale! WOW WOW WOW (RedShiftChris)
all pms replied
Old Apr 6, 2007 | 07:52 AM
rexman's Avatar
werd
Old Apr 8, 2007 | 07:57 AM
rexman's Avatar
bounce
Old Apr 8, 2007 | 09:57 AM
Old Apr 10, 2007 | 11:28 AM
rexman's Avatar
this **** is so pimp make you walk with a limp
werd up
Old Apr 10, 2007 | 11:42 AM
racer22's Avatar
how much for the necrofilac Rat?
thanks
Old Apr 11, 2007 | 06:12 AM
rexman's Avatar
Default Re: Rexman's Incerdible Blowout Sale! WOW WOW WOW (racer22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer22 &raquo;</TD></TR><TR><TD CLASS="quote">how much for the necrofilac Rat?
thanks</TD></TR></TABLE>
He's not for sale, do you know what it takes to train a rat to do that?
Old Apr 11, 2007 | 10:07 AM
yee SERIOUS's Avatar
HAHAHAHAHAAHAHAHAHHAA
Old Apr 12, 2007 | 11:32 AM
rexman's Avatar
Default Re: (kidsafe yee)
All I wanted was a Pepsi!
Old Apr 13, 2007 | 10:46 AM
91' LS-VTEC's Avatar
Default Re: (rexman)
pm'd you, no reply??
Old Apr 13, 2007 | 01:10 PM
kay_animation's Avatar
Post stalking
Old Apr 14, 2007 | 06:03 PM
rexman's Avatar
Default Re: (91' LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">pm'd you, no reply?? </TD></TR></TABLE>
pm sent!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay_animation &raquo;</TD></TR><TR><TD CLASS="quote">Post stalking </TD></TR></TABLE>
just because your paranoid dont mean they're not after you
Old Apr 16, 2007 | 11:44 AM
rexman's Avatar
a little bit of this... a little bit of that
Old Apr 16, 2007 | 12:20 PM
Ant-man's Avatar
I'm not sure what's going on w/ the photos, but I can't see any of them. It could be the firewall here at work.
What car is the Kamikaze header for? How many miles on the supercharger? Who did the porting on it?
----- Antony
Old Apr 17, 2007 | 11:21 AM
rexman's Avatar
Default Re: Rexman's Incerdible Blowout Sale! WOW WOW WOW (Ant-man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ant-man &raquo;</TD></TR><TR><TD CLASS="quote">What car is the Kamikaze header for? How many miles on the supercharger? Who did the porting on it?
----- Antony</TD></TR></TABLE>
The kamikaze header is for a B-series motor...
mileage unknown, fresh rebuild... i'd have to dig for the porter info...
T T T
Old Apr 17, 2007 | 11:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexman &raquo;</TD></TR><TR><TD CLASS="quote">just because your paranoid dont mean they're not after you </TD></TR></TABLE>
Sounds like a 2600 quote to me...
Old Apr 18, 2007 | 08:47 AM
rexman's Avatar
Default Re: (kay_animation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay_animation &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a 2600 quote to me...</TD></TR></TABLE>
Territorial Pissings- kurdt kobain, but im sure its been in 2600...
all pm's replied
Old Apr 18, 2007 | 08:58 AM
mr_nemesis2003's Avatar
Dont get F'd dead in the butt...
damn that was some funny ****
-rat is pending to me, lol
Old Apr 18, 2007 | 07:19 PM
racer22's Avatar
Free Bump!
Old Apr 19, 2007 | 01:49 AM
B18C1_CRX's Avatar
pm'd about the doors, man they look framiliar. haha
Old Apr 19, 2007 | 02:53 AM
EkJavi's Avatar
* B A N N E D *
nice stuff
Old Apr 19, 2007 | 05:11 AM
rexman's Avatar
Default Re: Rexman's Incerdible Blowout Sale! WOW WOW WOW (EkJavi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkJavi &raquo;</TD></TR><TR><TD CLASS="quote">nice stuff</TD></TR></TABLE>
thanks mang
i cant believe no ones noticed my spelling error yet... rofl
bounce
