Please diagnose
Old May 26, 2002 | 09:23 AM
CivicBoi's Avatar
Default Please diagnose
Please diagnose
Car only starts when engine is warm.
When its cold and i try to start it ... it just gives me a "click..click..click"
Any diagnosis will be appriciated...
Thank you
Old May 26, 2002 | 09:28 AM
89 CRX SI's Avatar
Default Re: Please diagnose (crxboi)
battery is dieing..... Charge it up or replace Try tapping starter when it does its clicking but i think it is a batery. Try triing one from another car.
Good Luck
Old May 26, 2002 | 09:30 AM
CivicBoi's Avatar
Default Re: Please diagnose (89 CRX SI)
Battery is good 12.72 volts..
Old May 26, 2002 | 10:04 AM
CivicBoi's Avatar
Bad solenoids...maybe?
How do i check for this?
Old May 26, 2002 | 11:25 AM
B16ED4G's Avatar
did you load test the battery? Just because it has a 12.72 surface charge doesn't mean its good. I 've seen a battery with a good surface charge and when it was hit with a load it dropped to 5.0 volts. might wanna hook a meter to the battery and watch the meter when you try to crank, see what kind of voltage drop you're getting. Also, see if your meter can read AMPS, see how many amps the starter pulls when you try to crank, if it shows no amperage draw when you turn the key, most likley a starter soleniod problem.
Chris
Old May 26, 2002 | 12:15 PM
CivicBoi's Avatar
Default Re: Please diagnose (B16ED4G)
12.72 when its cranking..(sorry didn't specify)
no amps when i turn the key ("click..click..click..sound").
starter solenoid problem..?
can you kindly give me some info on how to correct this problem
where??..and how???
thanks..
Old May 26, 2002 | 02:26 PM
CivicBoi's Avatar
Anyone?
Old May 26, 2002 | 04:56 PM
Chiovnidca's Avatar
where??..and how???
thanks..
If all your cables are clean and tight, it's probably a bad starter. You can take it to have it tested.
Old May 26, 2002 | 07:33 PM
89 CRX SI's Avatar
Default Re: Please diagnose (Chiovnidca)
or maybe you blew your battery fuse.. No never mind the starter is unfused. ummmmmm yea prolly you starter is shot go get it tested. Maybe you main realy. Can you jump your starter?????
Good Luck
Old May 26, 2002 | 08:31 PM
mafioso102's Avatar
New User
check all you connections.
Old May 27, 2002 | 01:21 AM
Stinkalope's Avatar
New User
It is very common to have a bad ground on the starter, it has happend to me a few times....just double check it..
Old May 27, 2002 | 11:30 AM
zCivic's Avatar
Did you reciently have your motor out or relocate your battery. Take a foot long piece of 4 gauge wire and ground you started. Put one on top its 8x1.25 bolt I believe and ground it to the chassis rail near the orginal place for the battery.
Johnboy0620
Oct 20, 2018 10:12 AM
SiB16A
Jun 11, 2006 12:37 PM
incognito E46
May 30, 2005 05:06 PM
B18C-RnVA
Nov 13, 2002 04:11 AM
