D16z6 swap for a B16 Please help!
Old Apr 2, 2007 | 06:33 PM
Frost_1097's Avatar
Default D16z6 swap for a B16 Please help!
I have a 93 honda del sol Si Vtec with a Sohc D16z6. I am about to put a 1993 honda civic B16 engine and transmission in it. My question is, what else will I need to change? ECu? wires? Axles? Mounts? or anything else I didn't mention? I could really use some help so this will run smooth. Thanks guys.
Old Apr 2, 2007 | 08:02 PM
Civic*B16A3*Eg's Avatar
Default Re: D16z6 swap for a B16 Please help! (Frost_1097)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost_1097 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 honda del sol Si Vtec with a Sohc D16z6. I am about to put a 1993 honda civic B16 engine and transmission in it. My question is, what else will I need to change? ECu? wires? Axles? Mounts? or anything else I didn't mention? I could really use some help so this will run smooth. Thanks guys.</TD></TR></TABLE>
Not being rude, but search. It keeps everyone happy and I guarentee you find the answer to your question.
Old Apr 2, 2007 | 08:11 PM
fmrprojects's Avatar
Default Re: D16z6 swap for a B16 Please help! (Civic*B16A3*Eg)
everything
Old Apr 3, 2007 | 07:10 AM
Default Re: D16z6 swap for a B16 Please help! (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">everything</TD></TR></TABLE>
Nuff said!
Yea you should just change the little things like that. For mounts go with hasport. They're worth it. Any b series axles will work. You're already wired for vtec so that shouldn't be that hard as far as wiring is concerned. It really is a straight forward swap. Any questions just ask.
Old Apr 3, 2007 | 07:11 AM
And as for the ecu I dont know. I just used the b16 ecu but I'm pretty sure you can use yours.
Old Apr 4, 2007 | 08:17 PM
Frost_1097's Avatar
I mean, will the engine and transmission mounts all be the same between the B16 and D16? If anyone has a write up or a link on how to do this swap it would help me out so much. please post it. thank you.
Old Apr 10, 2007 | 07:11 AM
Go to google and type How to swap b16 or something. You'll find it. It's on honda tech a million times. and no the mounts arent the same.
Fregoso16
Feb 9, 2014 08:26 PM
socal_dsol
Dec 4, 2010 07:40 PM
dragonhaven2001
21
Jul 11, 2003 07:49 PM
AdamQ3B85
24
Jul 4, 2003 05:29 AM
