im new please help me
My brothers im new in the page and my problem it(he,she) is that I have an ek 99 with an engine d15b the Japanese his ecu is one p2j is the v tec -e and I want to know the one who has the codes of this engine please help me......thanks
Imperious: Mod of Valor
Re: im new please help me (netovtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by netovtec »</TD></TR><TR><TD CLASS="quote">My brothers im new in the page and my problem it(he,she) is that I have an ek 99 with an engine d15b the Japanese his ecu is one p2j is the v tec -e and I want to know the one who has the codes of this engine please help me......thanks</TD></TR></TABLE>
What? I'm sorry. I don't understand what you're asking.
P2N was in charge of D16Y5 (OBD-II VTEC-E) and P07 was in charge of the D15Z1 (OBD-I VTEC-E). Though if you're using a JDM D15B you shouldn't be using either. It should be a P2J (I think) but you can definitely get away using a P28 (For '92-'95 USDM Si/EX) though that won't have 3 stage, that'll just have dual stage. So you can get an OBD-IIb to OBD-I conversion harness and run a chipped P28 with a JDM D15B basemap on it, run a P28 on it, see what the story is about the P2J, then see where you are from there.
I'm kind of confused as to what codes you're talking about - I think you mean ECU codes for that engine, but if you mean it's a JDM D15B it's only VTEC-E in the sense that it's a 3 stage VTEC setup - you'd need more than a VTEC-E ECU to run it as you need regular VTEC to engage as well.
Hope that helps . Sorry, I'm having trouble understanding exactly what you're asking.
EDIT:
Or are you asking the codes for for the check engine light?
https://honda-tech.com/zerothread/1901557
EDIT:
* B A N N E D *
Re: (rickeg6)
uhhhhhhhhhh the jdm d15b is not vtec-e ur going to need an ecu equal to a p28 not the vtec e one you have
so-re wa chigou no engine computer, CHANTO NO WA p28 d16z6
Re: (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">uhhhhhhhhhh the jdm d15b is not vtec-e ur going to need an ecu equal to a p28 not the vtec e one you have
so-re wa chigou no engine computer, CHANTO NO WA p28 d16z6 </TD></TR></TABLE>
If I remember correctly the JDM D15B uses a 3 stage VTEC system, it uses VTEC-E in the earlier RPM then engages VTEC (regular) at a higher one. That's why it's called 3 stage, opposed to regular VTEC or VTEC-E which is just a dual stage.
I think, anyways .
I think, anyways .
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
I think, anyways .</TD></TR></TABLE>
Yup ya got it.
VTEC-E works by only opening one intake valve at low RPMs then it opens both intake valves at like idk 4,800RPMs-5,300 (somewhere in between idk)
3 Stage VTEC works by opening 1 intake valve until like 2,300RPMs and then the 2nd stage kicks in which is 2 intake valves being used and finally the 3rd stage is simply VTEC as we know it where the cam profile changes for higher lift.
Yup ya got it.
hondatuner208
49
03-28-2008 12:58 PM
