B18C5 into 93 coupe??
Has anyone tried swapping a D16Z6 in a 93 civic EX coupe with a B18C5?? I'm hoping to make the swap soon but I wanted to know if anyone ran into any specific problems big or small with the swap. And if you've got any tips for me I'd appreciate em too thanks
You are removing the C5 for a Z6? May I ask why?
It's pretty straightfoward. Remove one engine, and put in the new assuming you have the mounts ready.
sorry I mean I'm taking out the Z6 and replacing it with the C5. I just wanted to see if anyone else had problems or any certain parts that need to be bought to help with the process
Make sure you have the mounts. Use the engine harness that comes with the C5 to make life easier. All you have to do is wire up the knock sensor if you plan to run a chipped P30. You won't have to wire it up if you use a chipped P28. The engine will drop right in.
try searching. there is a complete how to on putting b series motors in your car.
https://honda-tech.com/zerothread?id=856396
situations like such is the reason i have this link bookmarked.
https://honda-tech.com/zerothread/642479
civicracer1993
Mar 12, 2003 07:17 AM
civicracer1993
Mar 11, 2003 10:51 PM
