z6 in a ek won't start
Old Apr 2, 2007 | 05:17 PM
r1ch1e's Avatar
Default z6 in a ek won't start
helping my cousin with his swap. he has an ek and just put a z6 into it. theres spark, there's fuel. both ground is connected. can not figure out what to do? any help . need every help possible.
Old Apr 3, 2007 | 07:54 AM
r1ch1e's Avatar
Default Re: z6 in a ek won't start (r1ch1e)
no one?????
Old Apr 3, 2007 | 08:20 AM
pdiggitydogg's Avatar
is the timing belt set correctly?
valve lash?
Old Apr 4, 2007 | 06:32 AM
r1ch1e's Avatar
Default Re: (pdiggitydogg)
timing was never touched the z6 came out of a smashed eg that belongd to my cousin girlfriend's uncle.
Old Apr 4, 2007 | 06:40 AM
JDMFantasy2k's Avatar
Default Re: (r1ch1e)
sure the firing order is correct? That pwoned me pretty good one night. Also make sure the injector clips are on the right injector.
Old Apr 4, 2007 | 08:01 AM
agreed
im going to say firing order too
Old Apr 4, 2007 | 08:33 AM
silverboost's Avatar
so it cranks? check if u didnt flood it, check the order, i had a problem with mine when i used y7 spark plug wires, the werent long enought to fully reach the spark plug
Old Apr 12, 2007 | 09:59 AM
r1ch1e's Avatar
Default Re: (silverboost)
my cousin did the wires at night. i never thought to check the injector wires if it was connected correctly. how do i tell which plug goes to which injector?
Old Apr 12, 2007 | 10:01 AM
djsire's Avatar
check the ckp issue
Old Apr 12, 2007 | 10:13 AM
r1ch1e's Avatar
Default Re: (djsire)
what's ckp issue?
Old Apr 12, 2007 | 10:37 AM
Jakester9500's Avatar
are you using the right injectors for the ecu?
because i know one time i had y8 injectors running with the ecu for a y7 and it kept flooding everytime i tried to start it and i had to use the smaller injectors. then it started right up.
Old Apr 12, 2007 | 08:31 PM
r1ch1e's Avatar
Default Re: (Jakester9500)
the ecu is the stock cx ecu. i'm going to try the p72 then. thanks
playa24vtec
19
Nov 5, 2013 09:19 AM
turbotegy10
May 13, 2011 06:53 AM
chrysanderson
10
Nov 25, 2010 10:34 PM
CRX-Kid11
Jun 11, 2009 02:50 PM
GreenEHDriver
Sep 1, 2006 07:31 AM
