f2 fuction/form type 1 need help with dampening
well i just picked up this set of f2 type one's and im a newb at this whole dampening thing well i would like to know if anyone could help me with this, is the softest setting better for daily driving (would it be bouncy) but also good cornering? or is it better to have the harder settings for good cornering , and would it be more bouncy than the soft settings?
You should be able to run them at full soft all the time. Make sure you have about 5-6 full turns on the spring and leave it alone for now. Get most of your lowering ability from the lower mount by using the shock. Then fine tune your ride height using the spring. Usually a lil bit better be a lil lower than your target when using the lower mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW »</TD></TR><TR><TD CLASS="quote">You should be able to run them at full soft all the time. Make sure you have about 5-6 full turns on the spring and leave it alone for now. Get most of your lowering ability from the lower mount by using the shock. Then fine tune your ride height using the spring. Usually a lil bit better be a lil lower than your target when using the lower mount. </TD></TR></TABLE>
thanks for the info, but i think you can only turn the **** 4 times
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WattsUp$ »</TD></TR><TR><TD CLASS="quote">how much did everyone pick up there f2's for? im in the market for some suspension how do they ride...</TD></TR></TABLE>
i picked mine up for 450 got a good deal from a good seller
btw tested out my suspension today, pretty awesome had it on two turns from the highest setting.
Harsh ride from coilovers are cost by the shock that wasnt revalved properly to match the spring rates. Are these f2 valved? do they have shock dyno?
The proper method for increasing "dampening" would be simply applying a wet rag. If it's "damping" adjustment on your shocks your asking about, I cannot help you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">The proper method for increasing "dampening" would be simply applying a wet rag. If it's "damping" adjustment on your shocks your asking about, I cannot help you...
</TD></TR></TABLE> ha ha ha man your funny....no seriously i didn't catch that one.
you *****!
you *****!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itRspec »</TD></TR><TR><TD CLASS="quote">Harsh ride from coilovers are cost by the shock that wasnt revalved properly to match the spring rates. Are these f2 valved? do they have shock dyno?</TD></TR></TABLE>
im sorry im still newb to suspension, could you please tell me what valved means? but no i don't think they are valved and im pretty sure they haven't been dyno'ed
The best way to figure out what works for you is to try a bunch of different settings. Damping is more of a personal preference kinda thing than a "one setting is best" thing. You would do best to just drive the car on full soft, and then full stiff, because then you will KNOW exactly what the the changes do.
At first, I would adjust all 4 shocks the same. Once I found a setting I liked, I would try messing with the front/rear balance. Making the front stiffer and/or rear softer will increase understeer/reduce oversteer. Making the rear stiffer and/or the front softer, will increase oversteer/reduce understeer.
Basically, you won't know what you like until you try it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">The best way to figure out what works for you is to try a bunch of different settings. Damping is more of a personal preference kinda thing than a "one setting is best" thing. You would do best to just drive the car on full soft, and then full stiff, because then you will KNOW exactly what the the changes do.
Basically, you won't know what you like until you try it....</TD></TR></TABLE>
now thats an answer thats truly helpful lol thanks, i've been trying it now and i think i like the softer settings for daily driving
kaluwa3
Suspension & Brakes
May 13, 2007 03:39 PM
NeWnMpR0VeD
Suspension & Brakes
Oct 20, 2006 10:25 AM
