problems with chipped p72
Old Apr 2, 2007 | 04:21 PM
turbo1.5's Avatar
Default problems with chipped p72
I chipped a friend's p72 ecu with a chip kit from moates.net. His car is a 1995 Integra GSR with a AEM CAI and some crappy exhaust. The problem is no matter what bin I run (Crome or Uberdata bin) the idle bounces from 1000-1600 rpm and won't rev past 3000 rpm. I installed a switch at J1. With the switch "off" the car runs like normal. Thinking that I somehow fucked up the ecu, I tried a friend's chipped P13. The chipped P13 did the same thing, bouncy idle and won't rev past 3k. I tried a stock P13 ecu and it ran fine. So I thought maybe it was the Crome and or the Uberdata software. I burned a chip for a P30 in a '94 Integra LS (with a B16A2 ) using Crome and that car runs fine. What the expletive?
Old Apr 2, 2007 | 09:44 PM
BEST1TUNING.COM's Avatar
Default Re: problems with chipped p72 (turbo1.5)
Hey man. If you want you can send be your bin file and I will take a look. If worse comes to worse I can send you a chipped p72 that will work and you can send me the old one as a core. Either way shoot me an email: info@best1tuning.com with your bin attached or call 774-722-0885 and i will see if i can help you straighten things out.
-Hunna
http://WWW.BEST1TUNING.COM
774 722 0885
Old Apr 3, 2007 | 02:51 PM
turbo1.5's Avatar
I sent you a email!
b16bem1
May 14, 2013 11:25 AM
stackedhouse
May 17, 2012 05:37 PM
jdmdikk
22
Jun 30, 2009 06:04 PM
dsadas89das78934
Dec 10, 2004 05:13 AM
JDMlyfestyle
Nov 9, 2003 04:51 PM
