Suspension & Brakes Theory, alignment, spring rates....
My car is stitting to high on coilovers
Old Apr 2, 2007 | 03:13 PM
GSE980's Avatar
Default My car is stitting to high on coilovers
So I put my snkunk 2's on with the tokico hp and notice it was sitting really high I just thought it was because the engine was nto in so I drop my engine its the same height and even when the coiovers are all the way down so I meess with the allen key tightening it but it doesn't work it just moves the nut on top and nothing else am I missing something did I assemble these wrong
Old Apr 2, 2007 | 04:26 PM
tealj1's Avatar
Default Re: My car is stitting to high on coilovers (GSE980)
i think you might have put the coilovers on upside down
Old Apr 5, 2007 | 06:06 PM
GSE980's Avatar
there equally the same length it doesn't matter weather or not which way they are on
Old Apr 6, 2007 | 07:15 PM
street_ride14's Avatar
Default Re: (GSE980)
Your problem is a symptom of these actions:
1.) You did not cut the bumpstops to accomodate the lower ride height and now your shock is prest against your bumpstop.
2.) You left the oem dustcover on and the skunk2 sleeve is pressing against it not allowing you to adjust ride heght.
........... Cut the bumpstops in half and remove dustcovers and you should fine. I got the same exact setup om my Prelude and the ride is nice. I love skunk2 spring rates.
Modified by street_ride14 at 1:05 PM 4/8/2007
Old Apr 7, 2007 | 10:22 PM
donz's Avatar
Default Re: (street_ride14)
it's the dust cover if it is a prelude... if it was the bump stop your car would have to be dumped...
did you release the E brake?
Old Apr 8, 2007 | 08:47 PM
GSE980's Avatar
I cut the bumpstops in half I did leave the dustcovers on because to prevent corrosion what would the ebrake have to do with it ???
Old Apr 9, 2007 | 08:21 AM
super jdm yo's Avatar
it's your dust cover, the same thing happened to me.
Old Apr 9, 2007 | 02:25 PM
donz's Avatar
your dust cover is too small in diameter for the shock!!! do not drive!!! if you want dust covers you have to go find some rubber ones that will fit. The dust covers on the lude are metal tubes, and right now all the wieght of the car is sitting on these tubes which are sitting in the shock body... Go take them out now, and get come rubber dust covers... i have no idea why honda made metal dust covers on the lude, I also have no Idea why the the shock instructions do not have warning labels that tell you not to use them... If you look under you will see what everybody means about the shock cover.
also sometimes people just finish installing coilovers and the ebrake is engaged holding the car up higher... i don't think it applies to you.
dc2long
Apr 23, 2007 11:47 PM
dub from laos family
Suspension & Brakes
12
Oct 15, 2006 08:29 PM
tbud454
Nov 27, 2003 11:27 AM
95vtecgook
Sep 19, 2002 04:05 PM
