QUICK HEADLIGHT QUESTION
Old Apr 2, 2007 | 01:29 PM
401tuner's Avatar
Default QUICK HEADLIGHT QUESTION
after you remove the front bumper, and take out the headlight can you remove the lense from the headlight it self? Because im trying to clean mine because the seal broke and all inside the headlight there is water damage so im going to try and clean mine but i wasent sure if you could take the headlight appart, menaing the front lense. I just dont want to take the entire front bumper off and relize that you cant take the lense off.
Old Apr 2, 2007 | 01:38 PM
Try2Live4God's Avatar
Default Re: QUICK HEADLIGHT QUESTION (401tuner)
You can...but you would have to heat it to take it apart and you would have to reseal the headlight to stop the condensation.
If you don't have a whole day to do it, expect down time for your car.
Old Apr 2, 2007 | 01:40 PM
bg-33p's Avatar
Default Re: QUICK HEADLIGHT QUESTION (Try2Live4God)
shake n' bake
Old Apr 2, 2007 | 01:41 PM
401tuner's Avatar
Default Re: QUICK HEADLIGHT QUESTION (bg-33p)
damn, i figured you could just unbolt it. I wasent awware that you had to heat it to take it off. Oh well, i guess ill have to end up getting new headlights then, because theese look like hell and i have no idea hwo to clean them??
Old Apr 2, 2007 | 01:43 PM
bg-33p's Avatar
Post pictures they might be restorable. If they are just yellow on the outside you can lightly sand them and then wax/polish them. There's a thread about it, search for it.
Old Apr 2, 2007 | 01:47 PM
401tuner's Avatar
ok ill post pics, but yea they are a little yellow on the outside but its all yellow on the inside to. thats my problem.
Old Apr 2, 2007 | 03:01 PM
frontwheelfanatic's Avatar
if you have the time do them yourself, it's really not that hard. and it's actually pretty fun and the end result is worth the effort, plus you could do a little custom work while you're at it... i did
Old Apr 2, 2007 | 03:56 PM
98GSRDC2's Avatar
Default Re: QUICK HEADLIGHT QUESTION (frontwheelfanatic)
bake it clean it seal it
Old Apr 2, 2007 | 04:10 PM
Pzn801's Avatar
and if not...i want em
Old Apr 2, 2007 | 05:22 PM
401tuner's Avatar
Default Re: (Pzn801)
yea i took the front bumper off earler this afternoon and took the light off, and honestly took me about an hour to get the lense off the headlight it self. Put it in the oven at 225 for about 3 mins. I had to keep tkaing it out and trying to pry it off with a knife and a screw driver. I put it back in the oven at least 6 or 7 times. And now that i have it off and im cleaning it out completley, i have no idea how im suposed to put it back together seeing the glue/adheasive is still there and this looks like its going to be a bitchhh
Old Apr 2, 2007 | 05:30 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (401tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner &raquo;</TD></TR><TR><TD CLASS="quote">yea i took the front bumper off earler this afternoon and took the light off, and honestly took me about an hour to get the lense off the headlight it self. Put it in the oven at 225 for about 3 mins. I had to keep tkaing it out and trying to pry it off with a knife and a screw driver. I put it back in the oven at least 6 or 7 times. And now that i have it off and im cleaning it out completley, i have no idea how im suposed to put it back together seeing the glue/adheasive is still there and this looks like its going to be a bitchhh </TD></TR></TABLE>
Easier way would be 350 degrees for about 6-7 minutes,
and you Want the original glue/adhesive there for when you melt it back together.
Which all you do is throw it back in the over for about 4-5 minutes on the same temp,
then take them out when it seems gooey, and squeeze it all back together.
Old Apr 2, 2007 | 05:33 PM
401tuner's Avatar
Default Re: (CleanLikeJdm)
yea i read another post where it say put them in the oven for 22 mins at 250 degrees or something like that, all i know is that i made it so much harder on myself, because i was worried i was going to melt my lights hah
Old Apr 2, 2007 | 05:36 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner &raquo;</TD></TR><TR><TD CLASS="quote">yea i read another post where it say put them in the oven for 22 mins at 250 degrees or something like that, all i know is that i made it so much harder on myself, because i was worried i was going to melt my lights hah</TD></TR></TABLE>
Yeah, do the heats I said, and just keep an eye on them once it gets around 5 minutes,
I've done this probably 2-3 different times on about 4 headlights, so it works fine.
No need to bake at a lower temp, and take a Lot longer just to split, or reseal them.
Old Apr 2, 2007 | 05:58 PM
401tuner's Avatar
okay nice, ill try this tommorw thanks man
Old Apr 2, 2007 | 08:07 PM
H.A.S's Avatar
good
Old Apr 12, 2007 | 05:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">
then take them out when it seems gooey, and squeeze it all back together.</TD></TR></TABLE>
Is there additional glue/adhesive that I have to add to make sure there's no condensation?
Old Apr 12, 2007 | 06:31 AM
Exeed's Avatar
Default Re: (Try2Live4God)
Yeah, I'd do that as well... use 100% sillicone sealant to do this where needed.
peAches yO
Lighting
Jun 9, 2011 03:33 PM
sonnyleq
May 23, 2008 06:15 AM
HaRrYbOy
Honda Motorcycles
Jan 2, 2006 09:45 PM
Ronin Integra8
Jan 27, 2003 10:08 AM
