thrust washer clearance
Old Apr 2, 2007 | 01:06 PM
RACEPAK's Avatar
Default thrust washer clearance
hello everyone.
im reassambling my b16.
im using new acl main bearings and thrust washers. that i got way back from earl rip.
i noticed that there is about a 2 mm clearane between the right washer and the crankshaft and its due to a slight step on the crankshaft.
is that ok?
thanks
Old Apr 2, 2007 | 01:28 PM
IN VTEC's Avatar
Default Re: thrust washer clearance (RACEPAK)
2mm is definitely excessive, but you'll never know just by eyeballing it. Measure the crankshaft thrust clearance and then decide if you need a thicker thrust washer.
uboostivtec
Jul 1, 2010 02:28 PM
vtechjunkie
May 10, 2010 07:22 PM
mrDFWmechanic
Aug 18, 2005 04:36 PM
skunksol
Oct 13, 2003 08:43 AM
