ok misfiring part 2. found a solution i think?
Old May 26, 2002 | 06:58 AM
Audi A4's Avatar
Default ok misfiring part 2. found a solution i think?
ok well ive been misfiring in cyl3 for a while, no matter what i did ( new plugs, wires, cap, rotor.) it still always misfired, well trew the code for it.
well i left the motor run, and puul the spark pug wiere off cyl 3, and it ran the same. pulle doff # 1 and ran diff. so does that mean i have a dead cyl, being cyl# 3??? or bent valves?
Old May 26, 2002 | 09:20 AM
pny's Avatar
pny
Default Re: ok misfiring part 2. found a solution i think? (DRAG lll INTEGRA)
could be bent valves. Do a leakdown test and a compression test and see whats going on.
Old May 26, 2002 | 10:27 AM
IN VTEC's Avatar
Default Re: ok misfiring part 2. found a solution i think? (pny)
Good call. Fuel injectors and cylinder integrity are the next suspects.
Maybe if someone has an OBD-II scanner or a datalogger, you can get the injector pulse width and whatever other data from the ECU to see if the injector is even opening.
blueberryEG
Jan 25, 2014 12:55 PM
stevedrum4578
Jun 15, 2013 08:08 AM
turboD_EG
Apr 17, 2009 07:19 AM
phoshyzzle
Jun 9, 2008 11:03 AM
civicgeek133
Apr 3, 2006 09:38 PM
