D15 head on a D16 VTEC?
Old Apr 2, 2007 | 12:47 PM
re5513's Avatar
Default D15 head on a D16 VTEC?
My son went too long on his last timing belt change and thus bent some valves.
I have a chance to pick up a working D15 head cheap so I'm thinking about just swapping a D15 head on his D16 engine. Simple swap? I'd be curious to know your thoughts.
re5513
Old Apr 2, 2007 | 12:55 PM
mengy007's Avatar
Default Re: D15 head on a D16 VTEC? (re5513)
If the original engine is a d16a6 or sohc zc ( non vtec OBD0 ) and the new head came from an OBD0 or OBD1 ( d15b7, dx, lx, cx-b8 ) engine, d15b2 then just use the old Intake manifold and distributor and you should be fine I think.
what does it say on the block? Do you know if it's OBD0 or has it been coverted to OBD1?
Old Apr 2, 2007 | 02:40 PM
Bejita's Avatar
Just buy another D16 head....They arent expensive at all.
Old Apr 2, 2007 | 03:47 PM
dr_latino999's Avatar
Default Re: (Bejita)
Well if it's on a VTEC block you have to add the oil control jet back to the block.
Old Apr 5, 2007 | 02:18 PM
mengy007's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Well if it's on a VTEC block you have to add the oil control jet back to the block.</TD></TR></TABLE>Not on SOHC blocks. You just have take the oil jet plug out from SOHC blocks. It should be on the top of the block near the back between the 2 middle cylinders.
Old Apr 5, 2007 | 04:24 PM
Default Re: (mengy007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengy007 &raquo;</TD></TR><TR><TD CLASS="quote">Not on SOHC blocks. You just have take the oil jet plug out from SOHC blocks. It should be on the top of the block near the back between the 2 middle cylinders.</TD></TR></TABLE>You only remove the oil control jet if you are adding a VTEC Head to a non-vtec block. If you're doing the reverse you will need the jet back in its proper location.
Old Apr 5, 2007 | 07:15 PM
Jonknee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">You only remove the oil control jet if you are adding a VTEC Head to a non-vtec block. If you're doing the reverse you will need the jet back in its proper location.</TD></TR></TABLE>
Old Apr 6, 2007 | 07:30 AM
mengy007's Avatar
thanks for the correction
JJ's 90 Civic
Aug 1, 2012 11:44 PM
SoFresh1189
Jul 15, 2010 11:07 AM
TheAutoboxer
23
Apr 17, 2003 09:47 PM
