wheel hop?
i've got a quaife LSD in my LS tranny, omni coilovers, and stock mounts, but my wheels right now are 18's (long story, i kno they're not the best choice), but is wheel hop going to be a problem or no?
what about with a traction bar?
Im not sure if wheel hop has anything to bo with the size/weight of your wheels. Filling your motor mounts with urethane or going ES will help, with your launch.
you are most likely going to experience wheel hop so mounts help and aswell as traction bars. I highly suggest you change your wheel and tire combination. I am not sure of your suspension setup if you already had it aligned or camber kit but you need a proper alignment with wheels as big as 18 for these cars otherwise yours tires will get eaten up.
