water in spark plugs???
Old Apr 2, 2007 | 10:32 AM
blanco617's Avatar
Default water in spark plugs???
hi i was wondering if anyone can help me out a friend of mines left a motor covered under his porch and the tarp came of and water is in the spark plugs because he had no wires. what kind of damage does this do if any thanks. i dont want to waste my time putting the motor in for him if it is damaged.
Old Apr 2, 2007 | 10:37 AM
dognutz's Avatar
Default Re: water in spark plugs??? (blanco617)
If the plugs were in, the water should just be in the plug chamber. take a rag on a stick or qtips on a stick and keep going to its all out. Then you can remove the plug and look for rust in the piston chamber or on the bottom of the plug.
Old Apr 2, 2007 | 10:41 AM
blanco617's Avatar
Default Re: water in spark plugs??? (dognutz)
thanks if that would be the only problem it should be good the tarp was only off 1 day ill go clean it out today
Zaakro
Feb 1, 2007 11:29 AM
JoHA
Apr 6, 2006 01:53 PM
TheNasty0ne
35
Apr 8, 2005 08:27 AM
FitCRX
Jun 13, 2002 10:22 PM
wuhungsixxx
Jul 17, 2001 08:49 AM
