HOW TO INSTALL TURBO????
Old Apr 2, 2007 | 09:22 AM
slimjimdanny's Avatar
Default HOW TO INSTALL TURBO????
Anyone know how i can get some info on installing a turbo kit fo r my gsr? ANd do u have any pics of how to install it?
Old Apr 2, 2007 | 09:24 AM
Luserkid's Avatar
Default Re: HOW TO INSTALL TURBO???? (slimjimdanny)
If you have a bolt on kit just get a picture of any turbo car and see how it goes. If you have to fab stuff then your going to need some fab/pipe skills that paper wont show you.
ARMED's Avatar
ive never said this before but..
have you tried the search function???
Old Apr 2, 2007 | 09:34 AM
Heart4Audio's Avatar
i'm with you slimjim... i've got mechanical/ maintainence down, but a turbo is a new deal and i don't want to screw mine up. props for asking
Old Apr 2, 2007 | 09:53 AM
jsilva's Avatar
Default Re: (Heart4Audio)
Why would you give someone props for being lazy and not searching the numerous threads on here that give step by step directions on how to install turbo's on many different set ups? SEARCH is your friend.
Old Apr 2, 2007 | 10:54 AM
kaiba's Avatar
Old Apr 2, 2007 | 11:01 AM
jdm91CrxSi's Avatar
trial and error.. all you need is a turbo kit and some elbow greese..
my first project was like that.. you need 3 bar map, oil feed and return, hoses, fittings, intercooler, charge pipe, rubber connecters and clamps, manifold, turbo, tap your oil pan, get T fitting for oil sending unit, from back of your block on oil filter, need neptune tuning (my choice) boost gauge and a/f guage, 450cc injectors or bigger depending on your setup, and time..
Old Apr 2, 2007 | 11:11 AM
dek1mfk's Avatar
Default Re: HOW TO INSTALL TURBO???? (jdm91CrxSi)
check this link out its pretty easy and i dont know much bout engines and i installed mine im just waiting for my downpipe to come in.... https://honda-tech.com/zerothread?id=1263795
Old Apr 2, 2007 | 11:29 AM
Bejita's Avatar
I bet you blow your motor within' 6 months tops.
I say that because your so damn lazy that you didnt even bother to research before doing anything. By the way you asked it seems like you already have a kit but dont know **** about it.
There is a lot more to a turbo than just bolting it on kid. If you aproached your motor swap like this then I'm sure your car is a piece of ****.
Old Apr 2, 2007 | 11:31 AM
blaze_125's Avatar
If you already have all the pieces... Common sense, and knowing how to turn a ratchet is all you need.
If you're at the beginning stage and are currently building your kit; set your goal, and search to find out how to achieve it.
Old Apr 2, 2007 | 11:38 AM
CFF's Avatar
CFF
https://honda-tech.com/zerothread/1263795
93baggedcivic
Jul 27, 2007 07:04 PM
Fallen86
May 13, 2005 11:15 PM
princeperfect003
Jan 3, 2005 12:06 PM
95c1v1cs1
Feb 6, 2003 03:56 PM
