Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Pilot towing
Old Apr 2, 2007 | 08:35 AM
APEX CRX's Avatar
Default Pilot towing
ok who tows here with they're Pilot? I think this has been covered. I know the capacity for an auto trailer is rated for 4500. But I 've heard alot of conflicting info recently.
I plan on towing my CRX track car from now on and am concerned about towing a full open trailer and the CRX. U-haul won't even rent me a full trailer only a dolly set up.
Old Apr 4, 2007 | 07:09 AM
APEX CRX's Avatar
Default Re: Pilot towing (APEX CRX)
UH anyone? Bueller?
Old Apr 6, 2007 | 07:27 AM
quarterdimenickel's Avatar
I've never actually towed anything with my Pilot, but the CRX and the trailer ought to weigh less than 4k combined.
http://autos.msn.com/research/...id=-1
The information on this site has always been reliable, so I think you should be fine.
Old Apr 8, 2007 | 06:05 AM
slo blue's Avatar
Default Re: Pilot towing (quarterdimenickel)
ive seen team honda use a pilot to tow a 00 civic and they use the pilot to tow others cars as well. the back end will sag a bit if you dont like that there are air helpers that you could install inside the spring.
Old Apr 9, 2007 | 09:56 AM
APEX CRX's Avatar
Default Re: Pilot towing (slo blue)
thanks,
but its crap that u-haul won't even rent me a full trailer. It means I would have to buy one (which I don't have the space for) or dolly
I've heard mainly that the tranny is abit on the weak side for towing.
Old Apr 11, 2007 | 01:14 PM
RapeV-8's Avatar
very intersting because i m thinking about buying a 01,02 MDX! right now i have 92 toyota land cruiser ( use too much gas) about 11-12 mpg and i do use it for towing a dolly with a crx/ ef 4 door! i never check with u haul to see if i can rent a trailer but it is a full size trunk.
now i m thinking about sell the toyota and get a mdx doing to samething towing a crx or a 4 door!
what do u guys think????
Old Apr 11, 2007 | 02:56 PM
tmalzahn's Avatar
I have an 03 MDX and probably would not put my Integra (2800lb) on a full trailer.
The trailer itself can weigh well over 1500 lb plus the weight of your CRX (2000? with parts).
You might get by with a good set of brake pads and a larger trans cooler than comes with the hitch package. However, you may be at the limits and you would need a good trailer braking controller to balance things out.
Myself, I will use a dolly with my current MDX. If I had a new MDX or Ridgeline, I would use a trailer as they are both rated at 5000lb.
Old Apr 11, 2007 | 05:11 PM
VTC_CiViC's Avatar
Default Re: Pilot towing (tmalzahn)
I don't recall off the top of my head but I don't think the Pilot's came with A/T coolers like the Ridgeline, I'd defently add one before deciding to tow anything substantial.
Old Apr 13, 2007 | 08:20 AM
APEX CRX's Avatar
Default Re: Pilot towing (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">I don't recall off the top of my head but I don't think the Pilot's came with A/T coolers like the Ridgeline, I'd defently add one before deciding to tow anything substantial.</TD></TR></TABLE>
they didn't. you have to add a trans cooler and pwer steering cooler if you have a hitch on your Pilot. plus you need them so Honda would honor the warranty if you ever had a tranny issue.
I am debating on trying a dolly set up one time. I'm just leary of having my CRX "hang" on for life to a dolly and have my Pilot do all the braking. I would def be under the tow limit if I dolly or be at the limit if I do a full trailer.
Old Apr 13, 2007 | 11:19 AM
RapeV-8's Avatar
i hate to see my mdx/pilot wont able to tow a trailer! i may just have to buy a Qx4 instead
KayleeCRX
Mar 4, 2017 02:20 PM
komet 163
Jan 18, 2015 07:19 PM
tate_teg
Jul 17, 2008 12:31 PM
Tyson
Jul 27, 2005 01:37 PM
speedracer33
10
Nov 22, 2004 06:57 PM
