Eeeep!
Old Apr 1, 2007 | 10:21 PM
SupraRXZ's Avatar
Default Eeeep!
ok im not sure if this is bad or Im just trippin.
anyways i picked up my z6 motor to move it across the garage with my bro (head is off the block, #2 and 3 piston are down, # 1 and 4 are both up) so we move it and as we were carrying it the number 1 and 4 move down to half way. do you get what Im saying? they where at TDC but then they moved to about half way. am I trippin about it or is something wrong....? cause my bro gave me this motor cause something happend to the block (we dont know it was like knockin) so he got a new one and I was going to rebuild this one for turbo
oh ya and 2 and 3 still stayed where they were
bad bearing? crankshaft gone?
Old Apr 1, 2007 | 11:33 PM
Redline130's Avatar
Default Re: Eeeep! (SupraRXZ)
I would pull the oil pan off and check to see if the rods are still in one piece and/or attached to the pistons. Pistons should not just slip down the cylinder.
Old Apr 2, 2007 | 02:04 AM
Crimson_Tide's Avatar
Default Re: Eeeep! (Redline130)
yeah it sounds like those two cylinders threw their rods... that can be the only explanation b/c if they move down the other two cylinders have to move up if theyre all connected at the crank... just get a new engine- they can be found at a local junkyard for as low as $300 easily
-Josh
Old Apr 2, 2007 | 09:08 AM
SupraRXZ's Avatar
well I was going to rebuild this motor ( TT rods, Vitara pistons, etc...) would it be worth it? cause theres no scratches or anything to the cylinder walls
Old Apr 2, 2007 | 01:28 PM
SupraRXZ's Avatar
bump for more info
Old Apr 2, 2007 | 04:21 PM
SupraRXZ's Avatar
bump
Old Apr 2, 2007 | 08:54 PM
taking-back-sunday07's Avatar
Default Re: (SupraRXZ)
If the block is in good shape then GO FOR IT!! Might wanna replace main bearings and such while you got that beast opened up... http://www.autohausaz.com has them for like $40. Rod Bearings too.
Jimster480
Mar 15, 2011 01:14 PM
TcUiRvBiOc
May 16, 2007 01:29 PM
001020
Mar 20, 2005 06:51 PM
001020
Mar 19, 2005 11:14 AM
Westrock2000
Mar 30, 2002 04:31 PM
