need help on a vac leak on a z6
Old Apr 1, 2007 | 09:42 PM
Hella_Fresh's Avatar
Default need help on a vac leak on a z6
at idle the car will go from 1 to 2.5k and does that over and over.
all vac lines are hooked up, no holes in the mani or anything.
anyone ever have something like this happen? or know of anything i can try??
i was thinking maybe the intake manifold gasket?
i replaced the TB gasket also.
Old Apr 2, 2007 | 02:55 AM
BlueCrxNC's Avatar
Search for issues with EACV/IACV (Electronic/Intake, Air Control Valve), Idle hunting etc. This is a typical issue and has been covered many times. Reset your Base Idle. After this, spray Brake Cleaner or Carb cleaner all over your Intake Manifold to pin point any other leaks.
Old Apr 2, 2007 | 12:09 PM
Default Re: (BlueCrxNC)
yea im going to do that right now
Old Apr 2, 2007 | 01:51 PM
Default Re: (sXekid)
yea i cleaned them both and still does the same thing
Old Apr 2, 2007 | 02:41 PM
BlueCrxNC's Avatar
What have you done recently mod wise? Is this a new setup. When did it start doing it. Does it do it at all times/temps etc. What ECU are you running? Did you reset the base idle?
Lots of questions, but more info helps.
Old Apr 2, 2007 | 03:39 PM
its just a stock z6 thats obd0 with a pm6.
the idle has always done this since start up.
does this at all temps
Old Apr 2, 2007 | 09:01 PM
bump
Old Apr 3, 2007 | 08:11 PM
That EF
11
Mar 2, 2010 07:43 PM
93SiPrelude
Feb 24, 2008 10:39 PM
dorikingts
Sep 23, 2005 11:23 PM
98itr0448
Jul 10, 2004 03:17 PM
Hybrid96EK
Jun 3, 2003 09:10 PM
