ecu not showing codes
Old Apr 1, 2007 | 06:08 PM
flprelude's Avatar
Default ecu not showing codes
i have a 92 prelude and i swapped in a 96 h22a1, i converted everything over to OBD1, i have a p13 ecu for it. im about to put it on the road but im having a problem with my car stalling out. im trying to findout what is wrong with the engine so i go to check the engine codes and the end light says on. which usually means that there is an ecu malfunction. which cant be i just bought a new one and the car idles great but when it hits 4,000 rpms it dies? does anyone have any idea???????
Old Apr 21, 2007 | 06:19 AM
Tranam346's Avatar
Default Re: ecu not showing codes (flprelude)
sounds to me like you switched your MAP sensor around with your TPS sensor...just did an LS VTEC build, car idles great, stalled out at 3500....give it a shot, just double check all your wiring
dookiebox
Engine Management and Tuning
Jan 29, 2013 03:44 PM
b20vteclsintegra
Dec 30, 2011 10:07 PM
90integ
Jun 7, 2011 10:15 AM
PHILLIPDEEZ
Aug 13, 2005 11:21 AM
