dpfi to mpfi problems
Old Apr 1, 2007 | 03:58 PM
jaredvabeach's Avatar
Default dpfi to mpfi problems
well im in the process of converting to mpfi and i did everything i was told to off of
http://www.50mod.com/fourthgenhatch/mpfi.html
and now it wont rev past 2500
so i started checking voltage and everything is getting power except for the wires i had to run from the ecu for the crank angle sensor
so my question is should i be getting power from the ecu for the crank angle sensor or are there other things that might cause it from not reving past 2500 excluding the tps sensor
thankss
Old Apr 1, 2007 | 05:47 PM
civicstar's Avatar
Default Re: dpfi to mpfi problems (jaredvabeach)
your tps can cause it to not rev, did u make sure u switched the TPS wiring, another can be if u got the two wires that go to the distrib backwards
yesitismeee
May 13, 2012 04:53 PM
Lead_moose
22
Jun 7, 2010 02:11 PM
crxnonvtec
Aug 28, 2009 11:12 AM
civickid03
Jul 25, 2006 03:02 PM
streetdreams420
10
Aug 13, 2003 02:15 PM
