Clutch engagement problems on 92 civic. Need some help!!
Hey everyone, so here's the story. My clutch has been fine since i've owned the car. Than all of a sudden, my clutch engagement gets lower to the floor one morning. And the next morning the clutch doesn't engage at all and I can't get it in gear. I am going to adjust the clutch engagement level tomorrow but i don't know if that'll help. Any other suggestions/advise on the problem? thanks
its either a master or slave cylinder than. check for leaks/seapage under dash where plunger enters master. do the same with slave.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">its either a master or slave cylinder than. check for leaks/seapage under dash where plunger enters master. do the same with slave.</TD></TR></TABLE>
thanks, that will be the first thing i check
Most likely your cylinder is bypassing. You can replace this fairly cheaply (>$60 I'd assume). If the car is a 92 and no one replaced it, you got a pretty good life span out of it
They're designed to wear out so don't think you did anything wrong with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iSRT_Vtec »</TD></TR><TR><TD CLASS="quote">ok, than i guess thats the problem. I've seen some clutch MC's on ebay for like $40 shipped</TD></TR></TABLE>
Hit it up. Are they OEM? used? junkyard? warranty?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Hit it up. Are they OEM? used? junkyard? warranty?</TD></TR></TABLE>
It's an OE replacement with a 1 year or 12,000 mile warranty. I won't even own the car past this next year so it's good for me
