I Need Help with this connector
Old Apr 1, 2007 | 03:22 PM
corn0807's Avatar
Default I Need Help with this connector
I was changing the head gasket on my 95 honda civic and I accidently pulled too hard and disconnected a the green wire w/white stripe from its connector. The other wire is a red wire w/white stripe. Can anyone tell me what this connector does and how I can fix it thanx
I have no idea on how to post pictures on this website. Here is a link to the connector.
http://i158.photobucket.com/al...2.jpg
Old Apr 1, 2007 | 03:29 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: I Need Help with this connector (corn0807)
just push the connector back in with a tiny screw driver or if u really messed it up go to the juck yard and cut u another clip. and that sensor i think is some kind of temp switch
Old Apr 1, 2007 | 04:51 PM
tampajason's Avatar
wow and clean that bay up too lol
use a wirewheel on the bolts and lube everything up properly
Old Apr 1, 2007 | 05:23 PM
DrSeuss's Avatar
Default Re: (sxecrow)
ECT (Electronic Coolant Temperature) Sensor
Remove the pin from the connector and re-solder the wire onto the pin.
Old Apr 1, 2007 | 05:30 PM
corn0807's Avatar
Default Re: (DrSeuss)
Would I need an eyeglass screwdriver in order to pull out the pin?
Old Apr 1, 2007 | 05:51 PM
KtHaNxBai's Avatar
Default Re: (corn0807)
make ur car stick.
rustanghunter
13
Jun 27, 2010 05:45 PM
M4NNY
Aug 10, 2007 05:11 PM
REDBARON
Sep 24, 2006 07:08 PM
jisecup
Jul 9, 2003 02:53 PM
