i blew the mototr in my 93 del sol si
now i was just wondering i blew the motor in my car i have a 93 del sol si 1.6L non vtech dohc , now i wanted to now if i pull out a vtech from a si modle civic will i have to change my tranny and axiles as well or will the motor bolt on to my origanal tranny?
From: chillin in that city called queen creek, but homes the atl
u will need another sohc vtec motor to keep your original tranny and axles
and any sohc motor from 92-95 will work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams »</TD></TR><TR><TD CLASS="quote">u will need another sohc vtec motor to keep your original tranny and axles
and any sohc motor from 92-95 will work</TD></TR></TABLE>
he said it's a non-vtec dohc so sohc won't work.
okay so if i pull a 92-95 dohc motor it will fit but the ecu wire now is that anything big to do ? never played with honda much before . And i dont nkow too much about the motors , so if i get a 95 vtech outta a civic it will bolt in with out changing everything . LOL sorry for the questions i feel like a real moron
First of all before you get flamed it's VTEC, not vtech. Second, 92-95 civics did not come with a dohc vtec motor only the 97 delsol si usdm. do a search on how to wire vtec it's not hard you will need a p28 ecu an chip it or just get the ecu from the car you pull the motor out of. all b- series trans. will bolt to a b- series motors. so it will be a drop in motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 »</TD></TR><TR><TD CLASS="quote">First of all before you get flamed it's VTEC, not vtech. Second, 92-95 civics did not come with a dohc vtec motor only the 97 delsol si usdm. do a search on how to wire vtec it's not hard you will need a p28 ecu an chip it or just get the ecu from the car you pull the motor out of. all b- series trans. will bolt to a b- series motors. so it will be a drop in motor.</TD></TR></TABLE>
WRONG. The Del Sol had a B16 from 94-97. There is no such thing as a DOHC non-VTEC USDM B16. OP, check your engine, its most likely a D16Z6. Anything from any civic between 92-95 will bolt right up.
Modified by DeadEnd9009 at 8:34 PM 4/1/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">
WRONG. The Del Sol had a B16 from 94-97. There is no such thing as a DOHC non-VTEC USDM engine. OP, check your engine, its most likely a D16Z6. Anything from any civic between 92-95 will bolt right up.</TD></TR></TABLE>
YES there is such a thing as a DOHC-non vtec it's called a b18b you know the one thats out of an integra. And my bad your right it's 94-97. And if i recall he said he had a dohc in there.
okay thanks for the info i`m gonna try and get a vtec from a scrap yard in good condition most likely a 95 , now is there anything else i should know about the swap before i go buy my motor ? as is i`m think about just dropping the vtec in as is .
YES there is such a thing as a DOHC-non vtec it's called a b18b you know the one thats out of an integra. And my bad you're right it's 94-97. And if i recall he said he had a dohc in there.</TD></TR></TABLE>
i'm sure he meant there was not a del sol that came with a non vtec DOHC motor not that there isn't a non vtec DOHC motor
he lives in another country guys and his del sol has a dohc zc motor. but hes not telling us if he wants a b16 or a d16z6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iron_man »</TD></TR><TR><TD CLASS="quote">okay thanks for the info i`m gonna try and get a vtec from a scrap yard in good condition most likely a 95 , now is there anything else i should know about the swap before i go buy my motor ? as is i`m think about just dropping the vtec in as is . </TD></TR></TABLE>
i wouldn't do this take your car some where becuase u dont know **** about hondas
Oh Jesus. Where do some of you people come from? *sigh*
iron_man: Your 93 Si (if it's an Si) has a SOHC VTEC motor 1.6 liter. This is the d16z6 engine. It was available in 92-95 Civic Ex but ANY single cam engine will work with your current transmission and axles. I would try to find another D16Z6 engine as you wouldn't have to worry about ANYTHING. It all fits up. All wiring is the same. Done deal. If you cannot find a D16Z6 motor, a D15B7 will do ... but be significanly slower (and you'd need the ECU for it too). If you want to upgrade, you can pull ANY B series engine - b16a/b, b18a/b/c, etc and put it in but you will need transmission, axles, ecu, wiring harness (unless you really have an Si del sol and you can use the D16Z6 wiring harness and run a wire for knock sensor ... or get it tuned out by a tuner).
Hope that clarifies it for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sxecrow »</TD></TR><TR><TD CLASS="quote">Oh Jesus. Where do some of you people come from? *sigh*
I know exactly what you mean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">Holy ****...</TD></TR></TABLE>
Welcome to the club.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer »</TD></TR><TR><TD CLASS="quote">OK lets not be little kids fighting over whos right. I'm over this ****!</TD></TR></TABLE>
welcome to h-t
welcome to h-t
4wsB21a
Mar 6, 2002 04:31 AM
wuhungsixxx
Jun 21, 2001 12:55 AM
