Mis-firing issues? Or something else?
Old Apr 1, 2007 | 02:57 PM
digital sol's Avatar
Default Mis-firing issues? Or something else?
So just randomly a few weeks ago i started having issues with the higher rpm range. Car runs normal and strong, and pulls hard up top but it seems like its mis-firing or falling on its face around 8k rpms. My redline is at 8900 rpms and my shift light is set for 8300 rpms, at around 7800 rpms it kind of "pops" almost like im hitting a rev limiter, and i did an s2k cluster conversion and when i stare at the rpms and there climbing at around 7800 rpms they dont climb steadily anymore, actually the pegs/rpm indicator goes up and back as it climb's
it was tuned great a few months ago
set-up'
00 jdm itr swap
i/h/e
s2s1 cam shafts w/skunk 2 cam gears
msd ignition, msd external coil, msd cap, msd rotor
hondata s200 w/p28 ecu
aem fpr
Now i just changed my plugs this mourning to RM plugs and gapped them at 40, i also changed fuel filters and gave it some fresh oil. Problem dosnt seem to be as bad, during a drive today the rpms still kinda seemed "odd" around 7.8k+ but it wasnt making the popping noises how-ever if watching the rpm bars it was going up/down as it was primarily going up once above the 7.8k range'....Not throwing any codes
all ignition components are only 4-5 months old and my car is only driven a few times a week'
I may try to get an hour of dyno time and see if the problem shows up on paper or if im just being paranoid but it seems like an issue to me'
Old Apr 1, 2007 | 07:18 PM
HotboxedTypeR's Avatar
Default Re: Mis-firing issues? Or something else? (digital sol)
I'm having a similar problem. Does the coolant in your reservoir and radiator have any brown sludge in them?
Old Apr 1, 2007 | 10:44 PM
salman's Avatar
yeah, check that out!
Old Apr 2, 2007 | 02:23 AM
Default Re: Mis-firing issues? Or something else? (HotboxedTypeR)
nope, my coolant is clean
and what would that have to do with mis-firing? mis-firing is typically an issue with fuel or spark/ignitition
mybluesi
Aug 12, 2007 04:41 PM
Specialblend27
Feb 17, 2003 09:46 AM
Markaccord95
Jun 4, 2002 11:21 AM
