Crossthreaded Bolt on Fuel Filter...how to fix?
Old Apr 1, 2007 | 02:32 PM
95greenlude's Avatar
Default Crossthreaded Bolt on Fuel Filter...how to fix?
well after my fuel line on my nitrous kit bursting.....ALWAYS USE BRAIDED STAINLESS WHENEVER POSSIBLE!
well the fuel IN line from the gas tank to the filter stripped! i can go get a new line, but id have to replace that WHOLE line! what are my options??!?!
here is where it stripped....
Old Apr 1, 2007 | 02:39 PM
Hawkze_2.3's Avatar
Default Re: Crossthreaded Bolt on Fuel Filter...how to fix? (95greenlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote"> what are my options??!?!
Holy crap!
You can:
-cut the end off, put a new fitting on and re-flare that line
-get a whole new line and install it
-JB Weld that one (won't really be able undo it again)
-make a whole new line from either SS or a pre-made line form the auto parts store
Old Apr 1, 2007 | 02:49 PM
Default Re: Crossthreaded Bolt on Fuel Filter...how to fix? (Hawkze_2.3)
i know...i dont know how it happened...
i threaded it in with my hand normally, and thought everything was ok, untill i made a turn with the wrench and it popped back out! argh!
i'm probably gonna hit a junk yard this next weekend and see if they have one...
Old Apr 1, 2007 | 08:13 PM
GraphiteMW's Avatar
Would you be able to rethread it with a dye? I fucked up my rear upper control arm mount thread and used a dye and rethreaded it now the nut doesnt screw on half way then pop off.
Old Apr 1, 2007 | 08:55 PM
Default Re: Crossthreaded Bolt on Fuel Filter...how to fix? (GraphiteMW)
^im not sure....i'll have to go check if they make dyes that big.....
Old Apr 1, 2007 | 08:58 PM
GraphiteMW's Avatar
I'm 100% they do. Autozone won't have it, if you have a carquest around you check them, I am sure they have one.. they was the only auto-store that had one.. saved me from buying a new upper control arm!!!
Old Apr 2, 2007 | 06:40 AM
prelittlelude's Avatar
I would buy a new fuel filter and try and thread it in strait, if the fitting is too trached, you need to cut it and replace the fitting and re flare.
Eran
24
Oct 25, 2008 12:48 AM
JLefevers
Jan 1, 2008 09:20 PM
SpeedDreamz.com
May 30, 2004 02:07 PM
civickiller
Mar 27, 2004 06:43 PM
biglew
Dec 29, 2003 08:45 PM
